I have discovered a leaking air line in my EL1 System. The red line
from the manifold to the left wheel is pinched between the floor & one
of the frame cross members casing a leak. In looking at the setup I
cannot figure out how to get access to replace the line. The wheel well
has an inter liner and the lines exit the cabinet and go through a hole
in another fiberglass box under the wardrobe. How much do I need to
disassemble? What is the correct routing? Can I purchase the
replacement line at a heavy duty truck store or should I attempt to
repair the existing line?
Eric Tipton
etipton
Eric Tipton
etipton
