For the 23' I need a new device to provide warmth for the coach
*without* LPG.
What is the consensus among the GMCnet: Air heater or coolant heater
plus coolant-air exchange.
If shore power is available I will use a regular electric heater, but
for the times when shore power is not an option, I am looking for ideas,
and am currently undecided between an Hydronic (coolant gets heated and
another device transfers coolant temp throughout the coach using air) or
an Airtronic (air gets heated directly).
For me: Airtronic seems to be the least effort, but has the disadvantage
of being fairly loud, and you have the burn process in the coach.
Hydronic is a bit more effort, but it is supposedly less loud, as it can
be mounted in the engine compartment, and you never have the burn
Best regards
Peer Oliver Schmidt
PGP Key ID: 0x83E1C2EA
'76a Eleganza II 26', VA
'73 Sequoia 23', Germany, SH
*without* LPG.
Best regards
Peer Oliver Schmidt
