"By the way, you might want to put a relay near the compressor and have
the switches feed the relay and the relay take the power from the fuse
panel located next to the compressor. This would eliminate the voltage
drop caused by the long run to the compressor.
Emery Stora"
so if I am reading this right (I dont have a schematic yet) the power
comes from a 'hot' source, goes through the relay (which I have - looks
like a spdt horn relay), through the compressor motor, and to ground -
all of the control signals that come from the panel at driver site are
just low current control signals for relays and valves
if so I should be able to pick up hot and ground connections at the
cabin fuse panel - but then the compressor will be running off of cabin
batteries rather than engine battery - potential problem (low voltage) -
seems to me the best is to get hot from engine battery and use the cabin
ground as my return since it is so close to the compressor - at this
point I dont appear to have a problem with my existing hot lead just the
existing ground lead
where does the hot lead come from precently? - does it get routed
through the driver control panel on its way to the compressor relay? -
if so where is it attached to the engine battery hot lead?
yes, no, maybe?
ron keener near Austin, Texas
http://MidAmericaBreedingTech.com
* MidAmerica Breeding Technology
* Using Technology to Enhance Your Breeding Program
* chat at
http://forums.delphi.com/m/main.asp?sigdir=eamproducts
* ID-1 natural colostrum based immune system stimulant
* available as liquid or powder
http://www.colostrum.com
* Ovatec electronic heat cycle detection
* BirthAlert beeps you at foaling time
* SureFeed stops those wasteful feed slingers
http://www.eamproducts.com
* AlertoMast electronically detects mastitis in 2 seconds
* MiniMill portable minihorse exercise treadmill
* chat room at
* Little Big Man Exotics Ranch
* miniature longhaired Tennessee Woodenleg (fainting) goats
* and Great Pyrenees guardian dogs
* home of Zeigy - AnheuserBusch ZeigenBock beer mascot goat
http://www.hopnotes.com
* Amateur radio station WA0REE
* proud owner of classic 1978 GMC Birchaven motorhome
