>>2. YOu ideally want to adjust the front torsion bars so that each front
>>tire
>>carries the same weight. Same for the rears.
>>tom
As I understand how it should be done, ride heights are not adjusted by
checking how much air pressure is in each side of the vehicle, and as well,
I suspect most,or at least many vehicles, will NOT have equal weighting at
each wheel.
To correctly set ride height, it should be adjusted with the leveling
valves at the rear, measuring from the ground up to the the slots in the
frame,done on a level surface. When properly set, both front and rear, the
frame will not have torsional forces twisting it out of shape- regardless of
whether it is rigid or not.As well the frame will be slightly lower at the
rear than at the front, thus helping steering due to the increased castor.
It is an interesting experience to go to a weigh scale when the place is
closed and not being used, and weigh each wheel individually, and then both
front and both back together, noting weight for each scenario. Have your
wife move from one place in the vehicle to another and the side to side
weight on the wheels will change.
Bottom line is,unless the coach is perfectly and evenly weighted on each
side, then each wheel will have different amounts of weight on them in order
to keep the frame in neutral balance.
Claude
>>tire
>>tom
each wheel.
Claude
