Yes there is a duplicate bag, but it carries a very limited warranty as
Migule Mendes of MGM GMC saw two of those new bags blown out at our shop.
We returned all back and started using the larger bag from FIrestone.
Back in 1980-1990 there were guys like Roland Wilbur, Clarence Buskirk, Ken
toma and bunch of other great Mechanics and technicians I had the honor of
rubbing elbows.
Some refused to supply used parts to each so I ended up being the Pivot Man
and bought parts for them then and still do.
I will be 80 this year, so I have lot of memories.
> Hi Les and welcome.
> We heed to know the year and possibly the model of your coach. There are
> lots of places that your system can leak air. The year will get us started.
> Temperature changes will change the air pressure but only a couple of PSI
> and if that is the issue the pressure will return to normal when it warms up
> again. If you are having to add air to bring it up again then yes you
> have a leak somewhere.
> Early coaches (Power Level) had knobs on the air controls (Version 1)
> Later ones (Electrolevel I) around 1975 to 1977 had flat control switches
> mounted in the center of the dash or side panel to the left of the
> driver's seat. 1978 coaches had a 3rd version called Electrolevel II
> Let is know what you have and we will go from there with suggestions.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Jim Kanomata ASE
http://www.gmcrvparts.com
rubbing elbows.
> Hi Les and welcome.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Jim Kanomata ASE
