OEM air bags run between 90-105 psi. You can pump a bit more air into them.
Check if you have any plastic fittings, and go to a good truck part supply place and replace them with good brass DOT one's.
Leak down overnight, I think you will find easily. Leaking down after a few days, I think you may be better installing shut off valves right at the
Bags, and save your time trying to hunt down that leak. Especially on your newer Royale that I don't think has much air capacity, and you need to
find that leak with the pump running full tilt.
My coach drops in a bout a weeks time, not fully, but noticeably. When I leave it parked, I just flip the valve closed on the bags and it stays
level. When I go to leave, I flip the valve open and the air system is operational. Also forces me to do a walk around the coach once in a while
to look for other oddities. I could not find my leak.
Jon Roche
75 palm beach
St. Cloud, MN
Jon Roche
75 palm beach
St. Cloud, MN
