air bag info
diamondlouis
203
Does anyone recall seeing the pictures of how to put the cones in new bags?
I am getting bagged by the air bags trying to install them.
Thanks in advance.
Louie D
76PB
To:
Sent: Saturday, June 24, 2000 7:11 PM
Subject: Re: GMC: Aux Vacuum Pump
> from my web page
> Pump Second Source
> The vacuum pump I used is a complete unit including the pump, vacuum
> switch, and resilient
> mounting bracket --- everything you need except a filter.
> Pump: MP (Master Power) Brakes ---(704)664-8866 Part AC2723
> $269.95 plus $20.30 shipping from NC to OR. Mounts easily on the
> firewall "box" by the steering post under LH access panel.
> Vacuum Filter #675-5136, retail $10.60, Net $7.99. That is a NAPA part
> number.
> BTW, in the process of checking out my vacuum pump installation I found
> that I had a small leak in the original vacuum line to the
> booster.....probably never would have found it until complete failure
> had I not installed the pump.Gary
> This is available here from the local AC/Delco dealer for around $127..the
> pump# is AC215-119
> The AC2723 number above is the Master Power number and I had the AC/Delco
> dealer xref the
> Gm# 22034995.
> I found the 4-connection connector at Pep BoysCBWood
> gene
> >Can someone please post the PN for the Aux Vacuum Pump available from
> >Auto Zone IIRC the price was around $125 (?). Tried local AZ and they
> >needed a PN. TIA
> >Dick Missett
> >73
> >Wyoming, PA.
> Genef -- 77PB/ore/ca
> GMC MOTORHOME INFORMATION
> mr.erf
> http://www.california.com/~eagle/
I have seen the pictures somewhere. Seems to me they blow it up so it looks
like a long sausage with the ends sticking out. He then stood it on one
end and as he let out air he pushed the cone down into the bag. I have
heard this is hard. good luck
gene
>Thanks in advance.
>Louie D
>76PB
>From: "gene"
>To:
>> from my web page
>> Pump Second Source
>> number.
>> pump# is AC215-119
>> dealer xref the
>> Gm# 22034995.
>> gene
>> >needed a PN. TIA
>> >Dick Missett
>> >73
>> >Wyoming, PA.
>> mr.erf
mr.erf
>To: gmcmotorhome
>Subject: GMC: air bag info
>Thanks in advance.
>Louie D
>76PB
Louie, to install the cones, you need to put some air into
the bag so that the bag will resist your efforts to push in
the cone. While you are pushing, begin to let some of the
air out of the bag. The bag will then accept the cone. It
sounds complicated, but it is simple when you do it.
Good luck.
Scott Shean
Baton Rouge, LA
78 Royale
I followed the directions from the GMC service manual. It's not hard with a
air compressor but there is a bit of luck. I think Carol was holding my
temper for her own safety.
To:
Sent: Saturday, June 24, 2000 7:36 PM
bags?
> Thanks in advance.
> Louie D
> 76PB
> From: "gene"
> To:
> > from my web page
> > Pump Second Source
> > number.
$127..the
> > pump# is AC215-119
AC/Delco
> > dealer xref the
> > Gm# 22034995.
> > gene
> > >needed a PN. TIA
> > >Dick Missett
> > >73
> > >Wyoming, PA.
> > mr.erf
Someone asked for the OEM numbers of the Firestone air bags. How does
(708502 AY) sound
then more numbers: ( 2T2B - 15) under the Firestone logo.
Hope that helps, and thanks for the link for getting the bag over the cones
Louie D
76PB
To:
Sent: Monday, June 26, 2000 6:32 PM
Subject: Re: GMC: Watkins Glen NY Rally
> Nope she got a full dose of Ragussa goodies a step, final drive cover and
> tranny cover.
> Turned out to be a bad coil. I still dont understand it.Changed the
ignition
> module first and nothing, installed the new coil and fired instantly.
> >Tom,
> > I'd bet she's just pissed cause you didn't get her any Ragusa
goodies!!!
> >Nate '75GB (Lovin' this weather, 72 and Sunny on my H-D) Omaha
> >tomorrow will find out what is wrong. any bets? Carb or timing chain?
