Proceed with caution when straying from the FI9294 airbag on the Sullybilt
GMC suspension kit. The fact that the manufacturer or retailer of bag X
states that bag X is compatible with the 9294 but at a lower cost
is no assurance that you will not have fitment issues. Different airbags
built for the same application can have different dimensions which will not
impact their fitment on a truck trailer where clearances are huge but can
on a GMC where the clearances are much tighter. A Triangle airbag which is
a “direct replacement” for the 9294 has an inflated diameter 1/2” greater
than the 9294. This can cause clearance problems to the wheel well of the
GMC. If you are considering a less costly substitute to the 9294 on your
Sullybilt kit I recommend you install the kit on Bothell bogies less the
bag and measure to the inside of the wheel well from a straight edge placed
across the two plates. You will need at least 3/4-1” to clear a triangle
bag. The others, who knows? Is it really worth the gamble to save $100?
That is a personal choice.
Sully
Bellevue wa
On Mon, Jan 4, 2021 at 9:06 AM twlldeen--- via Gmclist <
> I was looking at a couple of replacement air suspension systems that use
> the Firestone W01-358-9294 airbag and ran across a list of equivalent parts
> produced by other manufacturers.
> Any issues/pitfalls or experience with these other products and do they
> fit the Sully system?
> AUTOMANN 1DK20F-9294
> CONITECH AS2924
> FIRESTONE STYLE 1T15LP-5
> FLEETPRIDE AS9294
> GOODYEAR 1R11-915
> TAURUS 6378
> TRIANGLE AS-8423
> TRP AS92940
> Larry
> Larry - Victoria BC -
> 1977 Palm Beach - 39,000 original miles so far
