I got the following wiring info from an electric car list I am on. Hope it
helps you with your vacuum pump.
>Here is how I have my GM pump wired on my EV.
>Connection A (Red wire) battery positive, 12 volts+ through a fuse.
>Connection B (Black with white stripe) ignition positive, 12 volts+
>Connection C (plugged) not used (not used in factory system either)
>Connection D (Black wire) ground, 12 volts-
>The pump is powered via the A connection, but will only run if it
>receives power from the ignition switch on the B connection.
Dave Mumert
dmumert
- -----Original Message-----
[mailto
wner-gmcmotorhome]On Behalf Of
RickStapls
Sent: Thursday, July 16, 1998 12:39 AM
To: gmcmotorhome
Subject: Re: GMC: Advice on tuning for high altitude please?
>If you or
>any of the other troops want, I'll give you a listing of older GMC vehicles
>that have the auxiliary vacuum pump on them. I purchased mine for a whole
>ten dollars in the local junkyard.
Jim,
I picked up one of these pumps in my local boneyard (paid $25, that's
Boulder for you) but I need a wiring diagram/info to hook it up correctly.
I
got all the associated vacuum fittings including a separate vacuum switch
that
was mounted near the booster diaphragm. (82 J2000). Investigating my
treasure when I got it home, I found a built-in vacuum switch and a circuit
board with transistors etc mounted on the pump itself. Further clouding
things, the pump connector has a 4-wire connector with only 3-wires used.
Not wanting to smoke any semiconductors, I put it on the back burner for
now.
Question: do you or anyone else here have complete wiring info/diagrams
for
this setup? Maybe Patrick could post them on his site? TIA.
Rick Staples
