So We are in Kansas tonight drove it 4 hours straight. Left out on I25 to I70. Not the best roads in the world but there were some spots that were
pretty smooth.
Scott it is not hard to steer in turns it just doesn't want to stay on a smooth curve it wants to "shopping cart" around the curve...best I can
describe.
Habbyguy its was only white knuckle when the drivers side upper ball joint popped out up in Montana. Outside of that it's one hand most of the time
unless it's rutted, multisurfaced or in curves. Then it's not difficult just way too much effort and concentration needed to actually enjoy the drive.
I've driven this thing 1500 miles so far and I've driven a lot of antique trucks so I get the overreaction thing. Heck after driving my 2010 F250
then my wife's car it takes some adjustment.
It mostly acts like a toddler in that as soon as you relax your grip it decides it wants to run off a little ...unless the road is really smooth and
flat. Otherwise it's left,right,left,right etc. Another bad is after 63 mph it starts to fish tail.
I think I need to recenter the steering gearbox. The PO had done that before the new balljoints and alignment. I also think I need some rear wheel
work as far as alignment goes (and maybe some upgrades and or new Bogie pins.) I think the front needs realignment after the the steering box is
reclocked. I may also have a loose suspension part or two as well.
Right now it's more like driving a water balloon than a "van" but if I can make it somewhat enjoyable then I'll probably keep it.
JimK. I plan to get with Ken if and when I ever get back to the Sunny (flat) South. I may give you a call later this week to discuss some of the mods
I have and where I need to go next.
Thanks all.
M Beam
75’ Avion Lots of Mods
Zuki Sidekick,
Dozier Al
pretty smooth.
describe.
Thanks all.
M Beam
Zuki Sidekick,
Dozier Al
