Advance or Not to Advance?
Tom Katzenberger
795
287
63
Guys,
I am installing a new timing set on an engine with 8,000 miles on it. it ran beautifully with the stock timing set, but I wanted to get rid of the 40
year old plastic gear set. I am replacing it with a Edelbrock double roller.
The question is: Should I advance the timing set 4 degrees to lower the torque band or leave it at the stock setting beings the engine only has 8,000
miles?
Thanks,
Tom Katzenberger
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
> Guys,
> 40 year old plastic gear set. I am replacing it with a Edelbrock double roller.
> 8,000 miles?
> Thanks,
> Tom Katzenberger
Tom,
My experience with can-shifting a 455 is near zero, but I bet if you put out a call (email or whatever) to Dick Paterson, he could give you a very
good answer.
My experience is that with a mild or stock cam, it might now get you very much. Cam-shifting I did really only matters near WOT.
There are two good reasons to advance the cam timing in a semi-stock
engine. One, to verify that all your timing marks are accurate (most of the
time, they are not), and two, as the chains break in, they stretch a bit.
This retards the CAM TIMING. So, if you start out with 4° or so of advance,
when it stretches it comes closer to correct. Many more considerations
here, but bandwidth police don't like my extremely detailed responses. If
you want more in depth explanations, contact me off gmcnet.
> > Guys,
> roller.
> > 8,000 miles?
> > Thanks,
> > Tom Katzenberger
> Tom,
> good answer.
> Matt
> GMCES
Than you Jim and Matt,
I settled with "0" as the engine is totally stock and only 8,000 miles with a double roller chain. I don't think I will need to push the stock
engine.
Now I am trying to set the crank seal. The book has .005 using the special tool. I do not have a special tool and I flushed the seal to the inside of
the timing cover, but I am not sure that is the best depth? Is there a method to set the seal depth without the special tool. Will .005 behind a
washer work?
Thanks again,
Tom
