Adjusting the original drivers seat
christopher taylor
29
Thanks Chuck, after digging around some I saw that the base plate could be
moved. I did not want to do this quite yet, don't want to have to mess with
the carpet..
I did tilt the seat back by moving the spacers from the rear of the seat to
the front and adding a couple of washers as well. This is much better for
me.
Chris Taylor.
Rochester, MN
To:
Sent: Sunday, June 04, 2000 11:01 PM
Subject: Re: GMC: Adjusting the original drivers seat
> I moved the drivers seat back by wrapping the base plate down over the
step.
> Just bolt the front though new hole and lag the wrapped plate into the
step.
> Also I raised the dinette 4 inches and bolts the seat belts to the
original
> seat belt nuts and used 1/2 in pipe for extended spacers.
> > The other thing I was wondering is if there was an easy and cheap way to
> get
> > the drivers seat to slide back farther. Or possible lower the seat an
> inch
> > or two?
> > Anyone done this? Thanks in advance.
> > Chris Taylor
> > 76 PB
> > Rochester, MN
> > ________________________________________________________________________
> > Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
I moved the drivers seat back by wrapping the base plate down over the step.
Just bolt the front though new hole and lag the wrapped plate into the step.
Also I raised the dinette 4 inches and bolts the seat belts to the original
get
inch
> or two?
> Chris Taylor
> 76 PB
> Rochester, MN
>the carpet..
>me.
>Chris Taylor.
>Rochester, MN
You can usually move a seat back a bit by just drilling new holes
either in the seat mount brackets that bolt to the top of the slides
or where the slide bolt to the base plate. This is a whole lot
easier than trying to move the base plate.
Emery Stora
77 Kingsley
Santa Fe, NM
