Tom,
You can certainly try it, but I predict unsatisfactory results. If you
look at the wiring diagram, you'll see that the gauge is nothing but an
ohmmeter measuring the resistance of each 0-90 Ohm sending unit. That
means that the current flowing through each of them is what's being
indicated on the meter. When you add a meter in parallel with the OEM one,
the current through the sender will be increased and that through the OEM
meter will probably be changed -- how is unpredictable without knowing more
about the impedance of that meter. That's for the selected sender. The
unselected meter and sender should be accurate, dependent upon the
calibration of the meter.
I suppose you understand how the tanks are plumbed and the meter
consequently works, but I'm going to run through it for those who may not:
The two tanks are connected at approximately the 6 gallon level by the fill
tube running down the left side of the tanks. That means that until there
is 6 gallons left in the selected tank, and therefore the meter, there is
an equal volume of gasoline in each tank -- and the meter should read the
same regardless of the tank selector switch. Only when there's less than 12
total gallons of fuel left should the gauge reading depend upon the tank
selector position. Basically what you'll likely gain by adding two more
gauges is the continuous reading of each of the two 6 gallons "reserves".
Now if you're looking for more modern, perhaps more accurate, readouts, the
correct way, IMHO, is to merely replace the OEM gauge with one new one, in
the original wiring location -- controlled by the tank selector switch.
However, be aware going in that the probable cause of any inaccuracy you're
now seeing is most likely the OEM senders -- they're merely float/lever
operated wire-wound rheostats, which can become erratic after 40 years of
life even in a benign environment, not to mention the terrible one those
have been in.
HTH,
On Sat, Feb 6, 2021 at 7:34 PM tom geiger via Gmclist <
> Once the weathers gets a bit better I am going to drop the tanks to get
> one of the sender units replaced. In doing this I was wondering if I can
> add
> a couple led gas gauges in addition to the OEM gauge? Was hoping the
> additional gas gauges just read the level in just the tanks they’re
> assigned.
> Just wondered if possible?
> Thanks,
> Tom
> Tom Geiger
> 76 Eleganza II
> KCMO
