Add-on Heater
tmaki1
462
Hi Bob,
We're celebrating our first year "anniversary" too (Labor
Day, actually). Congratulations!
> I thought we could get it up to my reliability
> standards in two months until I discovered this site. One year later it is
> still in our driveway being fiddled with. It has become a lovable
> obsession.
I know the feeling .
As to your add-on heater idea, I have no experiential
knowledge about mounting it under the dinette seat, but
PO of my coach mounted a similar heater in the
"headboard" cabinet of the rear bed area. 12-volt, 3-
speed fan, plumbed into the engine coolant lines running
from/through the water heater. He added a 120-volt
external heating element, and a circulating pump. Ball
valve shut off and bypass valves. Works great, especially
here in Southern California (coach was originally from
upstate New York where winter is spelled with a capital
W).
Feasible in your case? I'd say so. Work out your plumbing
and ducting, and there you go.
Surplus Center? I don't know about that. Sounds like my
kind of place. Where, how to contact, Web, tele (?)
Thanks and good luck!
Toby Maki
'73 Glacier 230
> I was perusing my Surplus Center catalog when I noticed a cab heater for
> $59.95, 12VDC, 3 speed blower, 5"x19" heater core, inlet valve for temp
> control... I thought of mounting this unit under the dining seat,
> diverting the engine coolant lines to the water heater and connecting the
> lines to the cab heater. I would fabricate a two way duct to either direct
> the air flow to the MH for additional cold weather heating or outside for
> additional engine cooling. Is this feasable or am I just spitting into the
> wind?
