Adapter for 3" to 1-1/2
alan bredbury
189
I used the marine pump, I mounted it in the genset compartment as the stated
lift on the suction side is something like 8'. I made my own adapter using a
barbed nipple and a 3" cap. I removed the threads from the (PVC not
nylon)nipple and bored a snug hole off center in the 3" cap then glued it. So
far it's holding fine. I tend to cheat (full machine shop available)
>>In a message dated 3/10/00 7:57:07 PM Central Standard Time,
>>Basheik
>>writes:
>and, if so, how do you adapt it to the outlet from the tank?
>>You should be able to find a male 3" to a 1-1/2" (male, I believe)
>>adapter which has the 1-1/2" offset to one side. Home Depot seems to have
>>the 1-1/2" centered but you want the offset one mounted with the 1-1/2" down,
>>so that the tank will drain without leaving an inch or so in the bottom of
>>the tank.I have seen them at local RV parts stores so they should be a common
>>item.
>>Emery Stora
>>77 Kingley
>>Santa Fe, NM
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
