ACCY 12V Fused/Switched Electrical Connection
RF_Burns
Super Moderator
Staff member
Sep 7, 2008
5,151
1,354
113
Ontario Canada
On coaches with the house battery at the rear and the compressor below the power cabinet, this is a common modification. Using the OEM compressor
power wire to power a relay, then run the compressor power from the house battery through the relay. The power coming from the house battery is
tapped off the #1 gauge power wire running from the rear coach battery to the from boost solenoid. This provides for a very low voltage drop under the
heavy current of the compressor.
Of course the power to the relay should be fused as close to the source as possible.
Bruce Hislop
ON Canada
