Hi All. I posted this on GMCNet and here to get as much input as possible.
The dash AC system in my rig was converted to R134 sometime in the past 5 years or so. The PO then replaced the R134 with Duracool (HC-12a). My AC still blows nice and cold, but there is a leak right under the front hatch on the high side where there's a T feeding refrigerant to two evaporators - the stock one and an auxiliary unit installed under the dash in the coach. I can see bubbles coming from the connection and there is oil on the lines. I've had no luck getting anyone to work on a Duracool system. I guess they're worried about liability. Do I need to buy an evacuator, tank, and vacuum pump and repair this myself? For those that use Duracool, do most of you work on your own systems?
I have no AC experience, but I guess there's no time like now to learn something new.
Update - The guys on the GMCNet forum suggested that I just let the system leak down and then I can depressurize whatever Duracool remains, fix the leak, and then take it to a shop to have the system vacuumed. Sounds reasonable to me so long as I don't damage the compressor in the process. I know it will shut down when the pressure gets too low.
