> Thanks Paul. I will get a ball valve this week. I think that is a large
> part of my problem. I am not sure about my condenser's efficiency. The fan
> clutch seems OK and without the tell tail oil spot in the center of the hub.
> When I service the freon the high pressure seems a bit high and will
Russ,
When I had the change over from Freon, the AC guy had the same type of
problem. He wnt through most everything and after he tore the whole
thing apart (I watched him rip the guts out to give advice and make sure
he did not hurt her) He found a piece of O ring in one of the hose
fiitings. It sat in there just right and would work fine for a while
and then go high pressure. When the compressor kicked off and recylcled
it would do it aagin. Hope that is not what you are facing.
Marcus
Russ,
Marcus
