I can use some advise and/or direction. Yesterday, I started the Onan in
mY '75 Avion GMC so I could have some air-conditioning while I worked in
some upgrades in the coach. The outside temperature was in the nineties.
The Onan and the AC worked fine for a while. Then the AC shut off. I
checked other 120vac circuits and found them to be dead. However, the
Onan kept running. I checked breakers in the Panel and found them to be
okay. I shut off the Onan and pulled the drawer to see if the breaker on
the generator had tripped. It was okay. Checked today to see if the heat
might have been the culprit. Alas I still have no current from the
Onan. Any advice will be appreciated.
Skip Newhouse
Skip Newhouse
