Todd I would if I thought I had a chance to make it work. It’s hard to fix when it run fine at home. I ran it for 4 hours the last time before i left for a trip. It quit within 30 minutes when on the road. I do not know what to do. I changed the coil, I changed the condenser, replaced all the diode. I plan to replace the oil sensor and change the oil. Then insulate the fuel line that runs under the generator.
Art
> FWIW I would make sure the genny works and run the roof ac to keep the
> coach cooler in really hot conditions before I would embark on a project as
> ambitious as building and running all that ductwork.
> Sully
> Bellevue wa
> On Thu, Aug 22, 2019 at 10:24 AM Jim Kanomata via Gmclist <
>> Not sure of the posting, however our Sanden compressor bracket does not
>> require it to be removed should the valve cover need be removed. Nice
>> benefit.
>> On Thu, Aug 22, 2019 at 9:29 AM Ken Henderson via Gmclist <
>>> Art,
>>> I don't quite understand your post, but what I think you're proposing to
>> do
>>> is to add ductwork from the front of the HVAC box, through the firewall
>> to
>>> provide more airflow into the cockpit. That MAY help with cooling --
>> quite
>>> a few people have done something similar. BUT, the fairly recent
>>> experience of a friend prompts me to issue a caution: Their engine
>> battery
>>> "exploded", causing a sudden burst of flame. The flame should have
>>> followed the firewall up to the base of the windshield and perhaps been
>>> extinguished for lack of oxygen. Or, at worst, burned through to the
>>> outside of the windshield. Unfortunately, a PO had added a plastic duct
>>> firewall above the passenger's feet. That duct was immediately burned
>>> through, allowing the flame to penetrate the firewall, and follow the
>>> cockpit side of it up behind the dashboard, along the inside of the
>>> windshield, over the passenger's head, etc., all the way to the back of
>> the
>>> coach. Essentially everything above the beltline was burned or badly
>> smoke
>>> damaged. Little damage below the beltline.
>>> Without that ductwork through the firewall, the coach might well have
>> still
>>> been totalled -- but with little or no interior damage.
>>> Just something to think about. I know if I were tempted as you are, I'd
>>> use very fire resistant materials (my custom HVAC box is made of 12 gauge
>>> aluminum).
>>> Ken H.
>>> Americus, GA
>>> '76 X-Birchaven w/Cad500/Howell EFI & EBL,
>>> Manny Brakes & 1-Ton, Troy-Bilt APU, etc., etc., etc.
www.gmcwipersetc.com
>>> On Thu, Aug 22, 2019 at 10:33 AM amansfield1104--- via Gmclist <
>>>> Never mine I took off the valve cover and had no problem putting the
>>>> compressor in. Hope this is worth it. Once i get it together I will
>> cut
>>>> some holes in the front of the box and run two tubes up to provide some
>>>> cooling. One will be run to the seat by the table to see if it will
>> cool
>>> a
>>>> little back there for my wife. Hope that helps cool down the RV a
>> little
>>>> where she sits.
>>>> Art
>>>>> On Aug 21, 2019, at 4:15 PM, amansfield1104--- via Gmclist <
>>>>> I have Jim K’s conversion. Is there a trick to installing the
>>>> compressor. I the brackets installed. I had to cut clearance for the
>>> fuel
>>>> line but other than that it went on without to much trouble.
>>>>> Art
>>>>>> On Jun 24, 2017, at 12:22 PM, Jim Kanomata
http://www.appliedgmc.com/products/full/1658.jpg
>>>>>> SANDEN 508 CONVERSION KIT
>>>>>> Price: $569.95
>>>>>> KIT INCLUDES SANDEN 508 COMPRESSOR --- 2 NEW HOSE'S AND A NEW
>> MOUNTING
>>>> BRAC
>>>>>> On Fri, Jun 23, 2017 at 8:39 PM, Jim Kanomata <
>> jimkanomata>
>>>>>>> We have supplied to several people that are running duel A/C units
>>> off
>>>> or
>>>>>>> Sanden unit.
>>>>>>> Sanden kit we supply come with mounting to fit the GMC MH slightly
>>>>>>> different than the Toronado.
>>>>>>> You can see it on our sight under Heating/Cooling
>>>>>>> On Fri, Jun 23, 2017 at 8:06 PM, Wayne Lawrence <
>>>> w.lawrence>
>>>>>>>> I noticed that most of the dash ac compressor replacements
>> Sanden, 4
>>>>>>>> seasons ect. have a lower displacement
>>>>>>>> than the oem a6. Any one who has used one of the replacements
>> which
>>>> one
>>>>>>>> did you use and do you notice any
>>>>>>>> loss of cold air? (this is if you had a working unit to compare it
>>> to)
>>>>>>>> Wayne Lawrence
>>>>>>>> 76 Birchaven
>>>>>>>> Bellflower CA
>>>>>>>> w.lawrence
>>>>>>>> _______________________________________________
>>>>>>>> GMCnet mailing list
>>>>>>>> Unsubscribe or Change List Options:
>>>>>>> Jim Kanomata
>>>>>>> Applied/GMC, Newark,CA
>>>>>>> jimk
>>>>>>> 1-800-752-7502
>>>>>> Jim Kanomata
>>>>>> jimk
>>>>>> 1-800-752-7502
>>>>>> GMCnet mailing list
>>>>> GMCnet mailing list
>>>> GMCnet mailing list
>>> GMCnet mailing list
>> Jim Kanomata
>> jimk
>> 1-800-752-7502
