A6 ac compressor replacement
wayne lawrence
132
I noticed that most of the dash ac compressor replacements Sanden, 4 seasons ect. have a lower displacement
than the oem a6. Any one who has used one of the replacements which one did you use and do you notice any
loss of cold air? (this is if you had a working unit to compare it to)
Wayne Lawrence
76 Birchaven
Bellflower CA
w.lawrence
We have supplied to several people that are running duel A/C units off or
Sanden unit.
Sanden kit we supply come with mounting to fit the GMC MH slightly
different than the Toronado.
You can see it on our sight under Heating/Cooling
On Fri, Jun 23, 2017 at 8:06 PM, Wayne Lawrence
> Wayne Lawrence
> 76 Birchaven
> Bellflower CA
> w.lawrence
http://www.appliedgmc.com
http://www.appliedgmc.com/products/full/1658.jpg
SANDEN 508 CONVERSION KIT
Price: $569.95
KIT INCLUDES SANDEN 508 COMPRESSOR --- 2 NEW HOSE'S AND A NEW MOUNTING BRAC
> Sanden unit.
>> Wayne Lawrence
>> 76 Birchaven
>> Bellflower CA
>> w.lawrence
>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
Hay Jim,
I was on your website earlier and also noticed the s6 replacement for our a6. Is either one (s6 or sanden)better than the other?
O by the way I still love the 370. Thank you for that.
Wayne Lawrence
76 Birchaven
Bellflower CA
w.lawrence
Wayne, That Aluminum S6 turned out to be a typical Communist Chinese
Crapola.
We sold lot of Vintage Air units with the Sanden compressors and realized
most had run lot of miles on them with no problems.
That's when we went with Sanden and have not had one come back in the 3
years. Most are made in Japan where they make private labels for
Lexus,Acura and others.
We are happy to see you are enjoying the 3.70 Final Drive unit.
When you get a chance try advancing the ignition timing 1-2 degrees as it
will make lot of difference.
On Sat, Jun 24, 2017 at 4:05 PM, Wayne Lawrence
wrote:
> Hay Jim,
> Wayne Lawrence
> 76 Birchaven
> Bellflower CA
> w.lawrence
I have Jims Sanden replacement, it works great. I have an AUX AC under the couch and I can cool the whole coach nicely.
The only issue is the bolts on the pulley, you HAVE to be careful that they don't hit your hoses when the motor torques over under load as it makes a great saw and will cut you hose. Ask me how I know!
My A6 never worked, so I can't compare
Sent: Saturday, June 24, 2017 6:18:47 PM
Subject: Re: [GMCnet] A6 ac compressor replacement
Crapola.
wrote:
> Hay Jim,
> Wayne Lawrence
> 76 Birchaven
> Bellflower CA
> w.lawrence
"That Aluminum S6 turned out to be a typical Communist Chinese
Crapola."
Jim
You didn't tell me that when I bought one from you. So far it's still working.
I hope I don't have to remind you of what you said soon.
Emery Stora
77 Kingsley
Frederick, CO
> Crapola.
