Gary,
I once watched a mechanic restart a Ford Falcon motor that had been sitting
so long it was locked up. He squirted a couple ounces of Marvel Mystery oil
in each cylinder and let it sit a day. This freed the engine up. He added
a quart of MMO to the crankcase and had another quart standing by while a
helper attempted to start the engine. When it finally fired up, it would
barely run and the helper did his best to keep it above 2000 rpm. The
mechanic began slowly pouring the remaining quart of MMO into the carburetor
and, by the time the can was empty, the engine was running smoothly. Of
course the smoke was so thick you couldn't see the back end of the car.
This recollection is almost 30 years old, but the details are still pretty
vivid.
I don't know that I would recommend pouring down the carburetor as this
could easily result in hydraulic lock if you don't do it right, but I'd
definitely try MMO in the crankcase before pulling the head.
Patrick
> It appears to have a stuck intake valve (popping back
> through the carb). I'm going to do a compression
> check and find out which cyl. Does anyone have an
> idea about how I can get this to unstick without
> tearing the heads off? Should I put a quart of Diesel
> in the oil? Mystery Motor Oil? Anything else?
> Remember, this engine has sat for 10 years now, and
> ran swell when they shut it down for the last time.
vivid.
Patrick
