Seems a lot of people want to remove the Isolator when they install a combiner. Here is a good reason why you should keep the Isolator and install
the combiner across it.
A couple of days ago when I started the Murray, the GEN light stayed ON. Checked the DigiPanel and it showed only 12V. So I got out the voltmeter and
checked the alternator voltage at the Isolator and it was near zero volts. My alternator was 11 years old, so I guess it had a good run.
I pulled the alternator and opened it up. The problem was clear, the jumper strap at the output stud was burnt off inside. The plastic insulating
washer was burnt off inside and badly melted on the outside. I cleaned up the stud, replaced the insulating washers and replaced the jumper strap.
Checked the bearings and brushes, everything else looked ok. Re-installed and we were back in business with a working alternator.
It was clear that the alternator output stud was likely (or would have) shorted to the case of the alternator. If I didn't have the Isolator, the
battery current would have flowed back through the #10 alternator wire causing lots of current, smoke and maybe flames. Its what us electronic types
call I Norton.
So you may want to keep your Isolator for just another layer of protection. The 0.7 volt drop across the Isolator that some say limit the battery
charging is a red herring. The alternator uses a remote voltage sensing wire which is connected to the battery. The alternator's internal regulator
uses feed-back from this wire and automatically raises its output voltage to compensate for any voltage loss.
Just my 2 cents!
Bruce Hislop
ON Canada
call I Norton.
Just my 2 cents!
Bruce Hislop
ON Canada
