A Friends GMC For Sale
neil martin
290
I have tried to post photos to the photo site. I have a friend selling his race/show car converted GMC. If the pictures done post I'll try again or
PM me and I can email.
His description:
Dear Neil,
Attached in several emails will be pictures of the GMC Car Hauler - the short description is as follows:
I purchased the motorhome off of Ebay in Florida and had it driven out to my shop in Camarillo.
We removed the rear fiberglas cap, stripped out the interior and floor (I still have most all of the furnishings
plastic wrapped on pallets). We then moved the rear wheels out a couple of inches and installed all new
bushings, bearings and airbags. We then replaced all of the brake lines and airlines while the floor was
out. We then replaced the floor with heavy duty - I believe 1" - marine plywood to make a new reinforced floor.
Two rows of etrack have been installed on the floor for tiedowns. We then made 2 x 2 steel hoops - one inside
the rear fiberglas cap and the other inside the aluminum body. These were then mated together with a full
length piano hinge - next we installed 2 electric jack screws which will lift the entire rear cap including the
bumper and rear tire past 90 degrees. We installed speakers and loading lights inside the rear cap.
I then had the outside repainted in the original colors.
When the air suspension is down, the rear portion is approx. 10 inches off the ground. With the two hinged
fold down aluminum ramps you have a flat loading angle.
Things that it needs:
2 automotive batteries
Finish the interior
Overhaul or replace the dash suspension air valve - it functions but I did not find
it to be totally reliable and when I stopped working on the project, I had not found
an NOS one.
I believe everything else is functioning correctly - every time I used it, it seemed to draw
more attention at the car shows then the cars I would bring in it.
I am open to offers - I know I will never get what I put into it which was the purchase price,
cost of parts, my hired labor - not counting my work is about over $30,000. I have no
idea what a fair market value is
Neil
76 Eleganza now sold
Los Angeles
Very nice, Neil! My kudos to Gary!
http://www.gmcmhphotos.com/photos/g7012-gary-27s-car-hauler.html
bdub
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Neil
Martin
Sent: Sunday, January 08, 2017 3:34 PM
Subject: [GMCnet] A Friends GMC For Sale
His description:
Dear Neil,
shop in Camarillo.
still have most all of the furnishings plastic wrapped on pallets). We then
moved the rear wheels out a couple of inches and installed all new bushings,
while the floor was out. We then replaced the floor with heavy duty - I
made 2 x 2 steel hoops - one inside the rear fiberglas cap and the other
inside the aluminum body. These were then mated together with a full length
entire rear cap including the bumper and rear tire past 90 degrees. We
Finish the interior
not find it to be totally reliable and when I stopped working on the
project, I had not found an NOS one.
it seemed to draw more attention at the car shows then the cars I would
bring in it.
the purchase price,
I have no
Neil
Los Angeles
Nicely done. I'm not interested in buying it because I have a similar project using a GMC. I am curious what the distance between the rear wheels
wells is and the outside width. Also, how did he go about widening the rear bogies? I assume he put some rectangular tubing as spacers and welded it
in?
77 Eleganza II, 403CI, Manny Brakes, 1 ton, tranny, lots of aluminum goodies.
http://www.bdub.net/pinkerton/
'03 Fleetwood Discovery 39L
I’m interested as well.
Also, what was the intended car to put in there?
I know that when I considered something similar, the nose of the Miata was right in front of the door.
Dolph
DE AD0LF
Wheeling, West Virginia
1977 26’ ex-PalmBeach
1-Ton, Sullybilt Bags, Reaction Arms, 3.70 LSD, Manny Transmission, EV-6010
> in?
Neil,
Get hold of Billy Massey as I know he can help your friend.
> or
> His description:
> Dear Neil,
> Finish the interior
> not find
> not found
> an NOS one.
> it seemed to draw
> the purchase price,
> $30,000. I have no
> Neil
> Los Angeles
Applied/GMC, Fremont,CA
He has the furnishings plastic wrapped in Camarillo? That's real close by!
I could use a dinette.
> Neil,
> again
> > or
> > His description:
> > Dear Neil,
> then
> were
> off
> > Finish the interior
> did
> > not find
> had
> > not found
> > an NOS one.
> it,
> > it seemed to draw
> was
> > the purchase price,
> > $30,000. I have no
> > Neil
> > Los Angeles
> Jim Kanomata
> jimk
> 1-800-752-7502
> wheels wells is and the outside width. Also, how did he go about widening the rear bogies? I assume he put some rectangular tubing as spacers and
> welded it in?
Kerry,
From my calculations, it need not be welded to the frame. But a piece of box tube might be handy. The thing my design ended up with was a deeper
thwarthships beem and a tensile strap underneath. The big issue was deciding just how close to 102" you can get. If you don't include the lugnuts,
you can get even closer.
> It is 106 ( a tad illegal) But whose measuring.
With my luck I'd get stopped the first time I got on the road. I can probably talk around the lug nuts and probably talk around measuring from
outside to outside on the tire, not the wheel. I'll have to do some calculations.
But if I'm going to go to the effort to make a car hauler that looks like this:
http://www.gmcmhphotos.com/photos/data/6130/Gilmoreoil_truck2.jpg
http://www.gmcmhphotos.com/photos/data/6130/GILMOREOILTRUCK.jpg
I'd prefer to keep it legal.
Btw, I'm not concerned about having a car tied down behind me. They haul cars on/in trailers all the time and I don't think I've ever heard of one
coming loose. I'd be more concerned with a chair or microwave flying forward than a properly tied down car.
