a fine line between genius and stupidity?
adam metzger
162
in my yard, I have a small retaining wall that drops down about a foot to the lawn below.
I had an stroke of genius/madness yesterday while at the lumber store looking to buy lumber to make ramps, cribs, etc in prep for "the fuel tank
wrasslin match"
if I build up two stacks of 2x8s the distance of the wheels apart, tall enough to equal the height of the wall, with one long board as a transfer, I
would in effect have a pit that I could work under.
If long enough, (about 2 feet in front of the mid wheel, or roughly 9 feet back from this spot) I would be able to drop the tanks from under there.
is this utterly stupid, or am i onto something here?
I wont tell you what my wife said.
1976 Palm Beach
Austin, TX
> in my parking area, I have a small retaining wall that drops down about a foot to the lawn below.
> wrasslin match"
> I would in effect have a pit that I could drive onto, and work under.
> there, and I could drive the front onto it too.
Adam,
If you are thinking of one stack of 2x8 under each side, it's been nice to know you......
If you stack 2x8s a foot tall on anything that can grow grass, the foundation will not be enough to have any sense of humor for side load. Unless the
load is perfectly centered, the stack may capsize.
Then, there is another stupid issue. That 2x8 is 7-1/2 wide. That is just barely a tread width of a 225 wide tire. That makes a close target to hit
from the cab. I think you want a 2x10 for the cap.
Several people here have made service ramps from wood. They were successful and even got to write about it later. I hope that one of them joins in
and can show you pictures.
Adam,
Be VERY careful if you go ahead with this, you need to consider the "hardness" of the ground under the 2 x 8's and how you would
assure lateral stability.
The Pedantic Mechanic
USAussie - Downunder
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Adam Metzger
Sent: Thursday, November 24, 2016 9:32 AM
Subject: [GMCnet] a fine line between genius and stupidity?
"the fuel tank wrasslin match"
as a transfer, I would in effect have a pit that I could work under.
from under there.
I'm with Matt, a 2x8 stack ramp will sink to one side on soil and tip over. I made a set using left over 5/4 decking. They were "6" inches wide so I
used 2 wide and it was just right for me at about 12" wide... But I use them in the shop on concrete. On soil I would want something at least twice
as wide as high.
Bruce "enjoying a cerveza by the pool in Mexico, still waiting for the Plumber" Hislop
Bruce Hislop
ON Canada
Hubler 1 ton front end
Adam, I made up four of these and they worked very well when I dropped my
gas tanks.
http://www.gmcmhphotos.com/photos/showphoto.php?photo=33783&title=12-ton-jack-stand&cat=5
> so I
> as wide as high.
> Plumber" Hislop
> Bruce Hislop
> ON Canada
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
Sorry, I only mentioned 2x8s because I was thinking of using them for ramps. So I actually would use 2X10s AT LEAST, or 2X12s. If I were to go this
wide, would YOU get under it?
1976 Palm Beach
Austin, TX
You could create a very similar ramp set-up to Ken Henderson's. He did use steel I beams for the wheels to ride on and guide in. These lead out to
another I beam for the ends to rest on. Has concrete columns for the beam assembly to rest on. I have been on his ramp and it is super. He has a
concrete pad underneath the ramp area. I believe that the ramp is about four feet from the ground level. Ken scoots around on a converted office chair
(no back) and has a comfortable work position.
Perhaps he will comment on it.
Tom, MS II
1975 GMC Avion
KA4CSG
http://www.gmcmhphotos.com/photos/new-service-rack-26amp-3b-drivetrain/p10327.html
You've got a good day start toward my better-than-a-pit rack, but you'll
REALLY want a good solid, preferably concrete, floor under it, for many
reasons.
Ken H
chair
Tom, MS II
1975 GMC Avion
KA4CSG
Ken, that's quite a set up! That's the idea I had, only about a foot off the ground.
Do I recall seeing someone driving their coach onto two railroad ties stacked?
Johnny bridges?
1976 Palm Beach
Austin, TX
These timbers are 1 foot square and the front wheels were at the inside edge while the rears were at the outside edge with the stock setup (no spacers
on front wheels yet. The timbers did bow a little when I jacked up the rear of them before I got the shorter blocks under them under the rear wheels.
http://www.gmcmhphotos.com/photos/2-extra-feet/p51514-first-stage-2c-then-jack-up-rear-ends-1-1-2f2-inch-at-a-time.html
http://www.gmcmhphotos.com/photos/2-extra-feet/p51507-ramp3.html
http://www.gmcmhphotos.com/photos/2-extra-feet/p51506-bridge04.html
The timbers are a full 12 inches wide; a 2X12 might not be wide enough to cover the different track of the front and rear wheels/tires.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
Good thinking!
Sent from my iPhone
> wrasslin match"
> 1976 Palm Beach
> Austin, TX
Ken
There seems to be a problem under your GMC. I noticed it as I glanced at
your ramp pics...disgusting...Wayyyyyyy too clean and areas where it
shines...
It does not look like mine!
Mike in NS
> Good thinking!
> Sent from my iPhone
> to the lawn below.
> > wrasslin match"
> there.
> > 1976 Palm Beach
> > Austin, TX
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
Wadn't me on ties. I use 4x4 treate3d cribs a couple of feet long set in much the same setup as the stands in the pictures above. When I'm jacking,
I put safety cribs close. Unfortunately, I mis-stacked them yesterday and this cost me a radiator. It also convinced me, when I do the inner flanges
of my newly rebooted axles, I'm gonna do it with the coach with its wheels on. Even cribbed, the idea of torqueing bolts and yanking and pulling with
only cribbing under leaves me cold, because I have to be compeltely under the front end. I'll let it sit where it's always safely sat. With saftey
cribbing 'just in case'.
Mike,
Maybe you need to pull the front clip, remove EVERYTHING from it, then have
it sandblasted and powder coated, like mine's PO did. ☺
> Ken
> shines...
> Mike in NS
> > Good thinking!
> > Sent from my iPhone
> > > On Nov 23, 2016, at 4:31 PM, Adam Metzger
> > to the lawn below.
> tank
> > > wrasslin match"
> transfer, I
> > there.
> > > 1976 Palm Beach
> > > Austin, TX
> > > GMCnet mailing list
> Michael Beaton
> 1977 Kingsley 26-11
> Antigonish, NS
> gas tanks.
The "12 ton" jack stands are something I've used for many years and posted on the photo site. I have removed gas tanks and black tank with no
problem with the GMC on these stands. If you are not going to use them on pavement then I strongly suggest you build them with a 3/4" plywood panel
on the bottom.
Here are some photos of the late Dwayne Jacobsons ramps:
http://www.gmcmhphotos.com/photos/g6004-dwayne-27s-ramp.html
Steve Southworth
Palmyra WI
Ken
Oops...I seem to have forgotten about that little sorry.
I think I'll mortgage my house so I can do the same...it sure looks GOOD !
Mike in Canuckland
On Thu, Nov 24, 2016 at 11:52 AM, Steve Southworth
> > gas tanks.
> on the bottom.
> Steve Southworth
> Palmyra WI
Michael Beaton
1977 Kingsley 26-11
Antigonish, NS
> spacers on front wheels yet. The timbers did bow a little when I jacked up the rear of them before I got the shorter blocks under them under the
> rear wheels.
It was bullitthead on the ties! Or what I thought were ties. I wouldn't drive the entire coach out on the boards. Just the front or rear, so I
wouldn't need to worry about the front/rear alignment. This wouldn't solve me needing work on wheels/tires/brakes.
1976 Palm Beach
Austin, TX
They are creosote treated, but not railroad ties. They are 12 inches square and 24 feet long. Part of a bridge used by a logging company to get the
trucks and equipment across a ditch to the logging site. They are so heavy my backhoe would not pick up the entire timber at once. I had to pick up
one end and drag them into place.
Terry Kelpien
73 Glacier 260
Smithfield, Va.
