I used an older version of the same unit. IIRC they did not have an
anti-reverse valve of any type, so they can suck air back in to the A/C
system as soon as you disconnect the air supply to the tool. Make sure
to disconnect the line at the A/C's vehicle connection before turning
off the pump.
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of
Kingsley Coach
Sent: Tuesday, November 21, 2017 2:22 PM
Subject: Re: [GMCnet] A/C vacuum pump
Tyler
You've just answered a question I was embarrassed to ask !!
I bought one of those several years ago and never tried it..it looked to
cheap to effectively do anything. I think the last time I looked, it
was somewhere in the area of where I keep A/C stuff, which is under the
trailer wiring stuff I think, which is right under the last box of crap
from my long gone and forgotten Airstream....
Thanks
Mike from NS
Virus-free.
www.avast.com
> If you are really on a budget I have used
https://www.harborfreight.com/air-vacuum-pump-with-r134a-
and-r12-connectors-96677.html
> the 18$ (and maybe a coupon cheaper) version with satisfactory results
> on several systems. As good? nope. 70% as good for 15% price? yep. and
> certainly good enough to know if system is leaking. A big air
> compressor helps a lot. I used to use it on a 10 gallon one...let it
> charge the air tank, discharge the vacuum pump, shut off vacuum, and
> recharge air. almost like bleeding brakes old style. 80 gallon air
> now, let er rip
> 1975 Glenbrook, 1978 Royale rear bath
> Raleigh, NC
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
