A/C upgrade
Thigh19
86
1
Okay, the dash a/c sucks and I’m going to add an additional Vintage Air slimline under dash unit. Also going to convert to Sanden compressor, and
everything else will be new, except the factory dash unit. My question is, do you “T” off the compressor to run both units? Plan on doing this
soon, if the parts ever show up;)
Am planning on the fresh air and recirculating mods to the coach, and installing a clear shower curtain, for visibility, as the divider.
Hoping these mods will make my wife complain about how cold the GMC is?
Thom High
73 Sequoia
Vancouver Washington
You can order a Sanden with the same connection as currently on your GMC. Then buy tees for rack line and run hoses to the new inside evaporator. They run well in parallel.
> Thom High
> 73 Sequoia
That should have read “each” line instead of “rack” line.
> Emery Stora
>> Thom High
>> 73 Sequoia
Take time trial fitting the Aux unit as it will tuck in .
We have sketches and pictures.
Some went ahead and slapped it in and sticks out and complained, when they
could have consulted me.
On Mon, Jul 26, 2021 at 8:10 PM Emery Stora via Gmclist <
> Emery Stora
> > Emery Stora
> and
> >> Thom High
> >> 73 Sequoia
> >> GMCnet mailing list
Jim Kanomata ASE
http://www.gmcrvparts.com
has anyone found a way to recess these units into the dash? Seems like they all stick out pretty far
Sent: Monday, July 26, 2021 10:20 PM
Subject: [GMCnet] Re: A/C upgrade
> Emery Stora
> > Emery Stora
> and
> >> Thom High
> >> 73 Sequoia
> >> GMCnet mailing list
Jim Kanomata ASE
