A/C Question
19,428
5
38
I need the opinions of those more HVAC knowledgeable than I am: Since the
pandemic kept us off the road for over a year, I find that the A/C no
longer works (equipped with a Sanden compressor and Duracool, it had
operated without attention for the previous 5 years or so).
A couple of days ago, I vacuumed the system down to near 30 in.HG. and left
it sitting until today, when it was still at almost that level. Then I
moved the vacuum hose to a fresh can of Duracool and opened the valves.
The low-side and high-side gauges both immediately indicated ~95 psi. Then
I started the engine and engaged the compressor. Neither gauge's needle
even flickered! Repeated compressor clutch cycles yielded the same
results: Click-clack of the compressor clutch and obvious rotation of the
compressor shaft -- yet NO needle movements.
I took a brass hammer and rather strenuously rapped the compressor (on
"hard parts") hoping I might shake something loose inside -- STILL no
needle movement with clutch cycling.
My diagnosis is that I have one of 3 problems in the Sanden compressor:
1. A sheared shaft; 2. A valve stuck open; or, 3. a busted piston -- in
that order of probablility. Does anyone, hopefully, have another/better
idea? Maybe even one that won't require compressor replacement?
It's looking less and less like I'll really need A/C in the GMC this year,
but I'd still like to get it working before I get still older and less able
to tinker, so Y'All's opinions will be greatly appreciated.
Good Morning Ken,
All I have is a few dumb questions.
Are the service hoses newer, with check valves in the ends of the hose?
Are the Schrader valve depressors in the end of the hoses screwed out well
enough
that they are positively depressing the Schrader valves?
Does the compressor "sound" like it is running?
Does it load the engine noticeably?
How many cans do you normally use?
Is there any noticeable heating of the compressor discharge?
Just hoping for something other than a bad compressor.
I'm sure some one else will have some other ideas.
Good Luck with it anyway.
Good seeing you post regularly.
Marsh (rarely Post) Wilkes
Perry Florida
-----Original Message-----
Sent: Tuesday, August 24, 2021 11:02 AM
To: GMC Mail List
Subject: [GMCnet] A/C Question
I have a very similar problem, my Dash AC stopped working, I have a new Sanden from Jim K, it used to work great.
I hooked up my AC gauges and they sat there like the compressor wasn't running. It was, the pully was spinning, both had some pressure, so the system was not empty
I didn't beat on it with a hammer but I guess that didn't help you either LOL
I didn't notice any lines getting hot or cold to the touch
Keith Vasilakes
Mounds View MN
76 exRoyale
MicroLevelhttp://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf
Sent: Tuesday, August 24, 2021 10:49 AM
Subject: [GMCnet] Re: A/C Question
Good Morning Ken,
enough
Perry Florida
To: GMC Mail List
Marsh,
None of your questions really have significant answers -- see them in CAPS:
> Good Morning Ken,
> NEW
> enough
> that they are positively depressing the Schrader valves? YEP
> Does the compressor "sound" like it is running? NO
> Does it load the engine noticeably? NO
> How many cans do you normally use? 3 -- LESS THAN ONE RIGHT NOW
> Is there any noticeable heating of the compressor discharge? NO
> Just hoping for something other than a bad compressor. ME TOO!
> Perry Florida
> From: Ken Henderson
> To: GMC Mail List
> Ken H.
I didn't figure you were missing a whole lot, just giving you what
I could think of.
Sure seems odd.
It'll be interesting to see what the outcome is, it shore don't
seem to be a pumpin.
Knowing you, you'll tear down the compressor to see what happened.
Let us know.
Good talking with you.
Marsh
Sent: Tuesday, August 24, 2021 2:32 PM
To: GMC Mail List
Marsh,
> Good Morning Ken,
> NEW
> enough
> Perry Florida
> From: Ken Henderson
> To: GMC Mail List
> left
> Then
> able
> Ken H.
Ken,
If you can see the compressor's clutch drive plate (right there on the front)turning when you power the clutch and nothing is pumping, then the clutch
must not be connected to the bevel part (Swash Plate? I forgot the name) the makes the pistons stroke. It can't be much else. The valves are all
individual by cylinder, even if one was jammed, the others would still pump something. It is pretty much the same for the pistons, but if one of them
broke loose, I would expect a tell-tale noise.
Unfortunately, the drive plate is mounted to the shaft with a flexible element, so you will have a hard time detecting a broken shaft by trying to
wiggle it. You could put a wrench on the nut and try to spin the and see if you feel anything like pumping.....
I have only once had a Sanden open, but there are some good things on Sanden's own sight, and a coupled of good YT videos.
If you are sure that the clutch is turning the shaft, there are not many choices left.
Please let us know when you find out what happened.
> I need the opinions of those more HVAC knowledgeable than I am: Since the pandemic kept us off the road for over a year, I find that the A/C no
> longer works (equipped with a Sanden compressor and Duracool, it had operated without attention for the previous 5 years or so).
> A couple of days ago, I vacuumed the system down to near 30 in.HG. and left it sitting until today, when it was still at almost that level. Then
> I moved the vacuum hose to a fresh can of Duracool and opened the valves. The low-side and high-side gauges both immediately indicated ~95 psi.
> Then I started the engine and engaged the compressor. Neither gauge's needle even flickered! Repeated compressor clutch cycles yielded the same
> results: Click-clack of the compressor clutch and obvious rotation of the compressor shaft -- yet NO needle movements.
> I took a brass hammer and rather strenuously rapped the compressor (on "hard parts") hoping I might shake something loose inside -- STILL no
> My diagnosis is that I have one of 3 problems in the Sanden compressor: 1. A sheared shaft; 2. A valve stuck open; or, 3. a busted piston -- in
> that order of probablility. Does anyone, hopefully, have another/better idea? Maybe even one that won't require compressor replacement?
> It's looking less and less like I'll really need A/C in the GMC this year, but I'd still like to get it working before I get still older and less
> able
> Ken H.
think Matt is correct... it is not that complicated of a system.
if it is like my Sanden, at least it is easy to get on the bench to see, and it is not crazy heavy.... then again maybe it is hard to reach on your
caddy 500??
clutch is probably most likely the issue especially with non-use.
Jon Roche
75 palm beach
St. Cloud, MN
I have a 77 which I think was the first year for CCOT. Your 76 probably has a POA valve? Perhaps some gentle hammer taps there on the valve stuck
open? I did get one on a 65 Olds to function by rapping on it.
Obviously at 1 can you are very undercharged, but need a pressure differential to add more
John Lebetski
Woodstock, IL
Matt,
I think you're probably right -- the flexible coupling to the wobble plate
probably failed. Your note about there being a valve per cylinder pretty
well cinches it -- I don't know why I was only thinking about one valve.
Guess I'll pull it off and tear it down, even before ordering the
replacement, out of curiosity. Fortunately, on the Cad500, it's mounted
right up front in the Vee of the block -- easy to get to.
Thanks,
> Ken,
> clutch
> them
> choices left.
> Matt
> psi.
> > able
> > Ken H.
> GMCES
Wouldn't you need more than one can in an empty system to get the compressor to kick in?
Larry
Larry - Victoria BC -
1977 Palm Beach 40,000 miles, PO said everything working but forgot the word NOT. New Atwood fridge, water heater & furnace. New SS exhaust system,
6000w Onan, Iota Converter, R134A A/C, New fuel lines & heat exchange hoses
Just have to jumper the low pressure switch harness to override the switch.
Unplug the harness from the switch. And connect the two wires together with
a jumper wire. The compressor will run, but if there is no refrigerant in
the system, don't run it for long that way. Once the compressor is running,
then you can add more refrigerant to the system and check for leaks and
pressures.
Salem, Oregon
> Larry
I connect the compressor clutch directly to +12VDC, bypassing the low
pressure switch, so, no, the can's pressure (95psi) is what the gauges
show. Without the compressor "sucking" the gas, there's no way to put more
in.
> Larry
Ken,
When you say gauges (plural) — are you using an AC manifold set? I know it’s a dumb question, but are you opening the center valve to allow the gas into the coach’s system?
-Dave
1978 Transmode near Pittsburgh
> in.
> Ken H.
On my car, the compressor doesn't kick in until I'm on the second or third can (car takes about 4). The vacuum created by the empty system should pull
the gas, right? In my experience putting a can in a pail of warm water speeds up the intake.
Larry
If both hi and low gages are reading 96 and the pump is rotAting the compressor is shot
Roy Keen
Minden,NV
76 X Glenbrook
It sounds to me like the drive coupling (clutch) mechanism has failed. It
may be due to normal wear 'n tear, or something like a compressor stall or
lockup. Either way, it needs to come off and onto the bench for a good
look-see, or possible replacement compressor.
You mentioned that it was a Sanden, I believe. Don't know much about
the longevity of those compressors, but the old OEM compressors would
outlast you and me combined, properly maintained, and cool a 2 bedroom
house to boot.
Salem, Oregon
> compressor is shot
> Roy Keen
> Minden,NV
> 76 X Glenbrook
Yes, using a gauge set with the center and low pressure valves open.
> Ken,
> -Dave
> > On Aug 25, 2021, at 4:46 AM, Ken Henderson
> more
> > in.
> > Ken H.
Your compressor doesn't kick in with the first cans because the low
pressure cutoff switch is not satisfied. I'm bypassing that switch and
powering the clutch straight from a 12VDC supply.
> Larry
I agree with you -- neither needle even quivers!
> compressor is shot
> Roy Keen
> Minden,NV
> 76 X Glenbrook
My Jaguar has a Sanden compressor that had a problem so I had to dismantle it to change the bearings and clutch.
The compressor is really two separate units, front clutch etc and the back piston area. I didn't do any work on the rear of the unit.
Apart from needing an inside and outside circlip pliers, I picked up a compressor tool kit on ebay for not too much money. The kit was somewhat useful
as I remember but I think probably more useful servicing units like the Harrison.
Some very good service videos on YouTube but you've probably viewed those already.
Larry
