A/C Problem
19,428
5
38
A couple of days ago, I got the GMC out and washed it, top to bottom. I'm
not sure the roof had been washed all over since the 2002 paint job!
Needless to say, it was DIRTY! Dawn mixed with lots of water and 83 yo
elbow grease finally got it looking pretty good.
Then yesterday I got inside, only to find lots of mildew. Seems sitting
closed up since 26 November 2019 wasn't its favorite condition. I got most
of that, including every square inch inside and outside of the
refrigerator, cured with Lysol wipes and more elbow grease.
Today I tried the TroyBilt generator. 10-15 seconds of cranking had it
running like a top and it was happy to power the roof air conditioner.
Then I went to fill the gas tanks (24 gallons) -- nope, I didn't top them
off before parking it. That's when I found out that the dash air no longer
produces even cool air. When I parked it last November, it was cooling
well. Perhaps needed a little more Freeze 12 but not bad at all for having
been untouched for 5 years+. But today, NO cooling. So, the refrigerant
must have leaked out, right? I've got a pretty good manifold set, and I've
used it a number of times over the past 15-20 years. And I've rebuilt,
redesigned, and repaired several auto A/C's -- but I'm NO EXPERT! I've
been lucky -- all the bits and pieces I've used have all worked, except for
the odd seal, hose, or belt which anyone could find and replace.
When I connected the manifold set, the high and low gauges, as expected,
read the same. I was a bit surprised to see 95 psi static, but so be it.
Then I started the engine with the A/C turned on. Still reading the same
on both gauges! Still about 95 psi! Hmmmm... I finally realized (with
being able to see it) that the compressor clutch was not engaging. Jumping
power to it directly from the chassis battery, I could hear the clutch
engage and the engine pick up a little load. But I saw essentially no
change on either pressure gauge!
Finally, I connected a fresh can of Freeze 12 to the filler hose. Opening
that caused the low pressure to rise sharply -- with no effect on the high
pressure side. Later, I disconnected the Freeze 12 and bled off most of
the pressure on the low side -- still no effect on the high side. Opening
the high side slightly caused a slow drop in that pressure -- I didn't
drain off much. It sits now with maybe 20 psi on the low side and 85 psi
on the high side -- after an hour or more unattended. The inside of the
coach is nice and cool -- with the roof air running on shore power!
SO, what say ye? What's plugged? I've never heard anything abnormal
sounding from the Sanden-clone compressor I've been using for about 10
years, so I find it hard to believe it's failed internally. But if not,
why is there no change in any pressure when I can tell it's running?
Where's the energy that the engine's obviously putting into it going?
Nope, the gauges are not stuck -- they respond perfectly normally.
After determining it was 111*F outside, I quit (only to have the
thermometer say it's only 91*F). I've no idea whether to attack the
thermo-expansion valve or the compressor or ???. Sure hope one of you
more-experienced A/C experts has an idea.
Thanks!
Ken H.cwipersetc.com http://www.gmcwipersetc.com
I would suspect the dessicant/drier/filter. Automotive A/C systems do not
like to sit without being exercised. Seals become elliptical from the
shafts sitting in one place for long periods of time, even though they are
supposed to be a completely sealed system, they are victims of
condensation, like the inside of your coach and refrigerator was. Just what
I would check first.
On Wed, Oct 7, 2020 at 2:41 PM Ken Henderson via Gmclist <
> Thanks!
Hi Ken,
I'm no automotive air expert, but I've done extensive maintenance and even
design
improvements on 35 ton multi-zone R-22 units that I later converted to 407C.
I actually have to go to work right now, I will ponder on your problem while
at work
and get back with you later. Someone will probably pipe up in the mean time.
From what I
am hearing though, it sounds like the metering valve (expansion valve) is
totally blocked some how.
Marsh Wilkes
Perry fl
Sent: Wednesday, October 07, 2020 5:40 PM
To: GMC Mail List
Cc: Ken Henderson
Subject: [GMCnet] A/C Problem
Thanks!
Hi Ken,
Thought about it a little.
Got some guesses and some questions, mostly just conjecture.
Why was the clutch not engaging, it should cycle off only on low pressure,
an unrelated problem? In theory the bulb in the thermostatic diaphragm
could have lost it's charge closing the expansion valve. That rarely happens
as it is a hermetic device and I am not sure it could close totally. From
what
you describe, it seems something in the system is totally blocked, but if
that's
the case and the compressor is pumping, you would expect to see a drop in
the
low side pressure, but may be not much rise in the high side as there is
little refrigerant
to pump, since it cant return to the low side. Possibly the compressor is
damaged and ran
long enough to plug the orifice, with debris and is not pumping much anyway.
Just a bunch
of guesses. What's needed is some more testing, starting with rerunning what
has already been done.
As Jim said a blocked filter/dryer is a possibility, I wouldn't expect a
complete blockage, but I don't
know for sure. The 95 PSI would seem to indicate liquid in the system (all
the refrigerant has not leaked
out) based on the ambient temperature and best I could find of a
temp/pressure chart for Freeze 12, actually
a very close correlation. Unless you are just getting some really spurious
indications (check everything again) it would
seem that you are going to have to open the system any way. If you have a
way to recover the refrigerant it would
be interesting to know how much refrigerant was remaining, although that
probably would not mean much in terms
of diagnosing the problem. Surely someone else will speak up with some good
ideas on trouble shooting. Do you have
a good local AC guy, I know you have a good machinist, a good auto electric
guy and I think a good welder among other
trusted experts.
Marsh Wilkes
Perry Fl
To: GMC Mail List
Cc: Ken Henderson
Thanks!
Ken 83 is only a number as long as you can keep going your not old. I know a 96 year old that is still driving a 40 ft Monico pusher with a pick up in
tow. When my wife tells me I’m too old to drive a Motorhome I remind her about nick . that high pressure you found before trying to start your a/c
is normal at high ambient temperature even with the system low on refrigerant. Keep those wheels rollin it’ll keep you young for a lot longer.
Roy Keen
Minden,NV
76 X Glenbrook
Ken,
What you are seeing (and I believe you) makes no sense unless you have at least two simultaneous problems.
Here are my votes, but I don't have any cures in mind.
The compressor has to have most of the discharge valves not functioning. If it pumped at all, the suction side would have pulled down.
There must be a liquid line blockage. This could easily happen in the TEX valve. If there were not, the low side would be coming up as expected.
My memory about this is shaky, but early in the No-R12 days, I had an A/C dummy load we used in dyno that got plugged up with stuff that seemed to be
like putty. We had no idea what this stuff was or where it had come from. I worked all my contacts and one of them had seen a similar issue when the
mineral oil of a R-12 system had mixed with the wrong PAL or ester oil in the 134 system.... And the recording ends there.
So, if you have the same goo, I can easily believe that it both made the pumps valves hang open and plugged up the TEX. Unfortunately and as written,
I do not know what to do about it. In my case, the pump still worked and I had one of my techs disassemble and clean the regulating valves in the
dummy load.
Please let us all know when you get it figured out.
Guessing stuck valves too. Did you evacuate the system before charging last year? Moisture may have made bad sludge. I’m no Sanden expert but
betting that don’t go 50 years like an A6
John,
I somehow misled you: The system has run with no attention for at least 5
summers. If there was any moisture in it, it should have caused problems
much earlier.
On Thu, Oct 8, 2020 at 1:16 PM John R. Lebetski via Gmclist <
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
