Frank:
Thanks for the clarification. Now I understand.
GM numbers I gave are different than your numbers, if you check, and I
realize you say casting numbers. Last four of the numbers are 5385 for =
the
left side and 5386 for the right side. Don't know what relationship =
casting
numbers are to part numbers???
NAPA numbers I have are 242-2072 for left and 242-2073 for right sides.
As far as Bobby is concerned, I recommend you contact him and find out =
if he
feels up to helping you. Or maybe you would care to go to his place =
and do
the work??
Paul
Sent: Friday, January 29, 1999 12:54 PM
Subject: GMC: 80mm caliper
Paul.
Lets start over again. The only reason that I mentioned the drum brakes =
is.
The Gm =BE and one ton truck with 13" rear drum bakes have the 80mm =
caliper up
front and also the larger master cylinder.
Checked the casting #. They are 18003532 GM L and 18003533 GM R. Your =
Gm #
have a 1 digit instead of the two 00. Paul I believe that they are the
correct parts but I will check them again. Will cross reference the Gm =
# at
Napa and then ask what year they are for. Maybe you can e-mail Napa =
part #.
I could then do it over the phone.
Paul I understand you are a good friend of Bob. Do you think that I =
should
just go ahead and have the work done locally
the
casting
if he
and do
the work??
Paul
Paul.
is.
caliper up
Gm #
# at
part #.
should
