Yesterday, on the way home from a rally, I stopped at a Flying J for
lunch and to dump my holding tank. While doing the latter I noticed that
my brake lights were on. In a minute I noticed that they had gone out so
I didn't think anymore about it. After I got on the highway I had some
difficulty getting my cruise control to work. About 15 miles farther
down the road we started to smell something hot so I pulled into a mall
parking lot for a check Before stopping, I noticed that the temp gauge
was getting close to the halfway mark . During my walk around I noticed
that the brake lights were lighted again. I got in the driver's seat and
asked my co-pilot to tell me if and when the lights went out. I stepped
on the pedal sharply. Lights stayed on. I put my foot under the pedal
and pulled up. The lights went out. I then checked the front wheels for
heat and found that they were quite warm and I could smell the same odor
that had entered the coach. We left the lot and cautiously drove the 20
more miles to home.
My suspicions are that a front brake hose has deteriorated preventing
the fluid from caliper cylinder to return to the master cylinder. Does
this sound logical?
Using the above assumption, I decided that this would be the right time
to upgrade to 80 mm calipers. However, I didn't know if a PO had already
done so. I pulled the right front wheel and loosened the caliper from
the rotor. I took the existing pads out and headed off to AutoZone with
my NET parts list. At the store I compared the size or the PF 1534 pads
with my old pads and found them to be very close in size(no appreciable
difference.) I went back to the coach and measured the piston diameter
of my old caliper (~72mm) and the piston diameter of the AZ 90184
(~75mm.) Does It sound like I already have larger than standard
calipers? I went back to AZ to measure a replacement caliper for the
original. They didn't have one in stock. Neither did NAPA.
NAPA did tell me that their part numbers 42-2010 & 42-2011 are for Cad
& Olds 1966-1978.
On my existing brakes I do not have a banjo hose so if I stay with my
calipers I'll need to search out a replacement number(s). Any guidance,
comments, and/or criticism will be appreciated.
Skip Newhouse
'75 Avion with hot stinky brakes
Western MD
more miles to home.
this sound logical?
& Olds 1966-1978.
Skip Newhouse
Western MD
