Bob Burkitt sent my some photos. Thanks SO MUCH Bob. There is a vacuum controller door that is out of site above the blower motor. On top. I had felt the door. But thought it was the top of the heater box. The door is stuck in the position that blocks off the outside air from coming in. ( But far from 100%. ) Bob had put a wire mesh over that opening to keep critters out. Great idea. Nice job. I'm going to make a plastic cover over that opening in the morning. I want to keep any hot air from entering the cold air area of my A/C system. Should also help in cold weather with the cold air infiltration. Yes. I'm blocking fresh air from entering the system. These GMC's just aren't that air tight. If I want fresh air. I'll adjust my Wind Wings. I've got a heater, and A/C system that I want to get every bit of performance out of them both I can. Thanks again Bob. Bob Dunahugh 78 Royale.
Sent: Thursday, May 31, 2018 8:51 PM
Subject: 78 dash heat/A/C. How does it get outside air?
Trying to figure out where outside air gets into the heat A/C box. Openings at the back of the box go into the coach. The opening on top of the box go to the defrosters. There are no openings in the left, right, bottom, or front. Remember that this box is used only on 77, and 78 GMC's. Have photos if interested. Bob Dunahugh 78 Royale
