> I've been told
>it has a '76 Caddy transmission.
> Is that good or bad? Anyone know if this
>automatically makes it a switch pitch?
The transmission is the same basic unit used in the GMC, however there may
be some small changes- the final drive on the vast majority of Eldorados is
a 2.73, with the GMC 3.07 optional which was in a few units. The internal
parts are pretty much the same, small changes may be present in the valve
body to make it smoother and more 'Cadillac-y' but its pretty much the
same, and should last about as well.
Cadillac's 500 Engine was used with this transmission, its a good strong
transmission. It will not have a switch pitch converter, and the regular
Cadillac converter is a slightly lower stall speed than a GMC would have
come with. This means its a direct coupling at a slightly lower engine
speed, which is a small difference. The main difference you probably will
discover is the speedo gears may have been retained from the Cadillac,
which will make it inaccurate, thats about all.
I wouldnt let it put you off the GMC a bit if it drives well in other
respects.
Hope this helps-
Brent
respects.
Hope this helps-
Brent
