76 Birch air conditioning - I'm going in
dave silva
1,090
This coach was restored in 2013 and then sat for seven years. I've been slowly recommissioning it.
The AC worked. Now it doesn't. Apparently a very slow leak. It has no pressure but it holds vacuum.
It had been converted to R134. I have a case of duracool.
So what do i need to know besides adding duracool and crossing fingers ?
Dave & Ellen Silva
Hertford, NC
76 Birchaven, 1-ton and other stuff
Currently planning the Great american Road Trip Summer 2021
It's gonna take a lot of Adderall to get this thing right.
If you have R-134a, and it was professionally installed, they used an oil
specifically compatible with that refrigerant. It will NOT BE compatible
with either R-12 or Duracool type refrigerants. The system must be pumped
down, the dessicant/dryer replaced, and thoroughly flushed of all that old
lubricant. If you have an OEM compressor, it should be drained and flushed,
and new lube filled. If you don't flush and replace the lube, be prepared
for a system full of sludge.
> Dave & Ellen Silva
> Hertford, NC
James
Duracool is compatible with the oil used with R12 and also compatible with the oil used with R134a.
If the system was properly converted for R134a then Duracool can be installed without changing anything.
Emery STORA
Frederick CO
> Salem, Oregon
>> Dave & Ellen Silva
>> Hertford, NC
Au Contraire' Emery.
R-12 lube is mineral based.
R-134a lube is not mineral oil, but is something called PAG which is a
synthetic lube. According to the Rules and Laws, R-134a and R-12 cannot be
mixed, that goes for HC-12a or "duracool" as well. Emery, you can do as
you wish, but those are the facts as I learned them from GM Training
School. Still have the books. I went and looked them up. Just what I was
taught.
On Sat, Jul 17, 2021, 7:05 AM Emery Stora via Gmclist <
> James
> Emery STORA
> 77 Kingsley
> Frederick CO
> oil
> pumped
> old
> flushed,
> > Jim Hupy
> > Salem, Oregon
> >> Dave & Ellen Silva
> >> Hertford, NC
> >> GMCnet mailing list
The one oil that both refrigerants ARE compatible with is called POE,
which is Polyol Ester Oil.
If, when the R-134a was introduced into Dave's GMC that oil was used, then
HC-12a can be added to replace R-134a with no ill effects. Just Sayin, that
is a big IF.
> taught.
> Salem, Oregon
>> James
>> Emery STORA
>> 77 Kingsley
>> Frederick CO
>> oil
>> pumped
>> old
>> flushed,
>> prepared
>> > Jim Hupy
>> > Salem, Oregon
>> no
>> >> Dave & Ellen Silva
>> >> Hertford, NC
>> >> GMCnet mailing list
>> > GMCnet mailing list
James
I still have to disagree with you on this.
If you go to www.duracool.com in their technical facts area you will find the statement “compatible with mineral and synthetic oils including PAG and ester oils”.
I am very familiar with PAG and I have been installing Duracool in GMC Motorhome for many years including conversions to R134a and have had no problems with Duracool and PAG oil.
Not sure when you had GM training school but I don’t think Duracool was around way back then.
> is a big IF.
> Salem, Oregon
>> taught.
>> Jim Hupy
>> Salem, Oregon
>>> James
>>> Emery STORA
>>> 77 Kingsley
>>> Frederick CO
>>> oil
>>> pumped
>>> old
>>> flushed,
>>> prepared
>>>> Jim Hupy
>>>> Salem, Oregon
>>> no
>>>>> Dave & Ellen Silva
>>>>> Hertford, NC
You are correct, in that I am not too well read on HC-12a. The last time I
attended GM Training School was 1985 or so. HC-12a was verboten in the USA
at that time. Still might be in certified AC shops, which I was. Don't
know if propane based refrigerants are compatible with synthetic
oils except as I already stated. That's all I know about that.
On Sat, Jul 17, 2021, 8:43 AM Emery Stora via Gmclist <
> James
> ester oils”.
> Emery Stora
> then
> that
> > is a big IF.
> > Jim Hupy
> > Salem, Oregon
> be
> >> taught.
> >> Jim Hupy
> >> Salem, Oregon
> >>> James
> >>> Emery STORA
> >>> 77 Kingsley
> >>> Frederick CO
> >>> oil
> compatible
> >>> pumped
> >>> old
> >>> flushed,
> >>> prepared
> >>>> Jim Hupy
> >>>> Salem, Oregon
> been
> >>> no
> fingers
> >>>>> Dave & Ellen Silva
> >>>>> Hertford, NC
I have to go with Emery on this .25 years ago I converted a hundred ton commercial system from r12 to 134. I replaced gallons of mineral oil with
ester oil. Generally you could add duracool to an r12 or 134 system to top it off but it isn’t legal a tech could loose their license doing this not
to mention a fine.
Roy Keen
Minden,NV
76 X Glenbrook
So have we reached a consensus?
I did replace R134 with Duracool in a Ford Expedition and it worked great for several years.
But apart from the dispute over the refrigerant, are there any other steps to resurrecting this system, assuming it is intact?
Dave & Ellen Silva
Hertford, NC
Kinda preparing to go thru this as well. I have a 76 Eleganza so in the same boat. Did the PO do the recirculation mod on the air box?
Tom Geiger
76 Eleganza II
KCMO
No idea.The work was done by the COOP. Not sure what standard options are and i haven't asked Jim B. about the AC
What is the recirc mod and how can i tell ?
Dave & Ellen Silva
Hertford, NC
Dave,
You are gambling with $40 worth of duracool.
You can pull a vacuum, make sure it holds that vacuum. Your patience on how long to watch the needle
Drop varies on how
Much you care about $40 or having to add more later. I dont have patience so usually I only hold a vacuum for maybe an hour at
Most,
Most times it is however long i go inside to get something to eat
Or drink.
Then pop on a can, fire up engine. Short out the “high” pressure switch plug so compressor kicks on and let it take that can add the others and
then start watching pressures. Get someone to get the rpms up.
You will find your $40 charge will last forever. Or eventually
Might need another $6.99 can someday. I have seen some last and my friend Ed we put
A can in just before summer. This time i think i might know where our leak might be. (Valve core). So will find one and try that.
You could go through alot
Of work and guessing to search out leaks. Chances are $40 worth of duracool will probably keep you cool as needed.
Jon Roche
75 palm beach
St. Cloud, MN
> Dave,
> and then start watching pressures. Get someone to get the rpms up.
Thanks, that's the info i was looking for.
It actually held vacuum for a long time, like overnight.
Dave & Ellen Silva
Hertford, NC
Jon
How would it be a $40 charge. If you use the recommended 3 cans at $6.99 per can it would be a $20.97 charge? If you put in $40 worth you are overcharging the system.
Emery STORA
>> Dave,
> Dave & Ellen Silva
> Hertford, NC
One of my favorite tools is the Mastercool 91490 Schrader valve core installer tool. It allows you to change a valve core while maintaining pressure in the system. I’ve used it for more than a few repairs and for some reason I am just fascinated by the ingenuity of the tool. https://www.mastercool.com/ /91490https://www.mastercool.com/product/91490/
-Dave
1978 Transmode near Pittsburgh
3 cans of genuine duracool were just dropped on my doorstep yesterday. I am going to evacuate the “frostycool 12a”
I have a case or more left if frostycool.
My new vintage air setup seems to tend to blow not as cold over time. Not sure why, i have adjusted charge up and down. I dont think it is
freezing up, with looking in with boroscope i dont see any frost problem.
Friend who does home hvac work for a living, but also had done gmc air, claims to only use genuine duracool and he experienced poor cooling from
another non-duracool r12a, and now will only reccomend genuine duracool.
The frostycool seems to work well for others vehicles and my friend ed’s stock gmc. So the non-scientific opinion is difference on how the
mixtures effect pressures for the expansion valve.
So for $40, I am going to see if genuine duracool works better. I can report after next week.
$6.99 a can. X3. + $10.66 shipping was $37.65. I rounded up.
Jon Roche
75 palm beach
St. Cloud, MN
It’s amazing how much shipping adds to the cost nowadays!
Emery STORA
> Jon Roche
> 75 palm beach
> St. Cloud, MN
Is/are there some recommended source(s) for that tool? D C "Mac" Macdo=
nald Amateur Radio K2GKK Since 30 November '53 USAF and FAA, Retired=
Member GMCMI & Classics Oklahoma City, OK "The Money Pit" TZE166V1=
01966 '76 ex-Palm Beach k2gkk + hotmail dot com __________________=
______________ From: Dave Stragand Sent: Sunday, Ju=
ly 18, 2021 09:31 To: gmclist =
Subject: [GMCnet] Re: 76 Birch air conditioning - I'm going in One =
of my favorite tools is the Mastercool 91490 Schrader valve core installer =
tool. It allows you to change a valve core while maintaining pressure in th=
e system. I=E2=80=99ve used it for more than a few repairs and for some rea=
son I am just fascinated by the ingenuity of the tool. https://na01.safeli=
nks.protection.outlook.com/?url https%3A%2F%2Fwww.mastercool.com%2F&d=
ata 04%7C01%7C%7Ce2bb8618b05644fc467f08d949fa2daa%7C84df9e7fe9f640afb435a=
aaaaaaaaaaa%7C1%7C0%7C637622161120648018%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC=
4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=
hpddhYPew7Uh4qSeym6v0b4Fwdjv2BH2db2Rdz0wMG8%3D&reserved 0 /91490 -Dave 1978 Transmode near Pittsburgh =
