'74 body side moulding seal
steve southworth
3,088
Having the coach repainted. Removed the body side moulding. Not an easy job. Had to use care not to bend the stainless steel mounting.
When taking off the SS it appeared there were two narrow strips of butyl rubber doing the sealing. The strips appeared to be about 1/4" wide. One on
the upper aluminum to aluminum extrusion. The other on the aluminum extrusion to fiberglass. These butyl strips appeared to have a fabric stripe
facing that caused the butyl not to stick as strongly to the SS. It was very adhered to the body. No signs of leakage onto the extrusion.
What does nayone know about these butyl strips, the facing, and is it still available?
It is amazing that after 47 years the rubber is still flexible and sticky. It sticks extremely well to shoe soles when it is stepped on.
Steve Southworth
Palmyra WI
Steve,
You can buy that in rolls at hardware stores. Used for setting house
windows. The rolls I’ve seen are ribbon about 3/4” wide and 1/8” thick.
Will provide decent hold with accompanying screws / rivets.
Sully
Bellevue wa
On Thu, Jul 8, 2021 at 11:57 AM Steve Southworth
> on
> stripe
> still available?
> Steve Southworth
> Palmyra WI
Steve,
I don't think that it really matters about the facing on the butyl tape as the stainless molding will probably stay on for another twenty or thirty
years after your paint job. The extra stickiness to the stainless won't affect anything.
There is one possible exception, and it's probably a remote one - the facing might be a belt and suspenders approach as a barrier preventing the
stainless from contacting the aluminum extrusion and creating that undesirable dissimilar metals galvanic reaction. Just a guess...
Richard
'77 Birchaven TZE...777;
‘76 Edgemonte
Call and discuss with JIm Bounds of Coop as he does tons or that type of
work and can help you.
> Steve,
> affect anything.
> Richard
> ‘76 Edgemonte
Jim Kanomata ASE
http://www.gmcrvparts.com
It may also be a good time to preempt the possibility of chipmunk cheeks. I drilled additional holes in the molding and replaced all screws with #10
stainless screws which were long enough to go all the way through the panel. This in theory will prevent the side panels from bulging and developing
"Chipmunk Cheeks".
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
