I believe the link for the presentation is:
http://gmcws.org/Tech/Getting_Your_GMC_Under_Control.pdf
*Kimberlea Weeks | GMC Motorhomes International *
Vice President of Administration | Convention Manager
Admin Address: 1214 N Jefferson Way, Ste 352, Indianola, IA 50125-1400
612.501.4600 | f.866.519.0047 |
www.gmcmi.com
Corporate Address: 1402 S Cage Blvd, Unit 273 | Pharr, TX 78577-6288
> Ball joints, particularly the lowers, can be quite sloppy without affecting
> steering or alignment.
> But, the tie rod ends and drag link joints are a horse of a different
> color. Where they wear the most, is in the center of their travel, not at
> their extremes. Any looseness in the middle is immediately felt in the
> alignment as well as the steering wheel. Upper ball joints on a
> GMC need to be fairly tight, because they really affect alignment. The good
> side of this is, they rarely wear out.
> Steve Ferguson did a great technical presentation on
> replacement/repair of lower control arms. I believe it can still be found
> on the GMCnet photo site. Great instructions.
> Salem, Oregon
> On Sun, Jan 9, 2022, 10:22 AM John R. Lebetski
> > Part number errors, once wrong in the system, seem hard to erase, even in
> > the GM system. If Rare Parts were more knowledgeable they would extend
> the
> > fit to FWD TZE chassis 73-78 all.
> > The slight allowable slop in the lowers is allowable because it is the
> > weight bearing joint. As soon aa it is loaded the slop of the ball and
> > socket
> > is self zeroing. Most important is proper A arm ‘massaging’ and dry
> > fitting of new ball joint during install (a take away from Lenzi seminar)
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
