455 with Higher Compression Pistons / Persistent Pinging Under Load
Haven't seen the original poster on this thread in some time... But if he comes back, some of the best money I've spent on my coach is the addition of an AFM.
Thanks for all that! I assume you mean air/fuel meter? Monitoring 2 gases or 4?
I've spent a lot of time with those struggling to get vehicles through emission.
What kind of numbers are you running? Can't say it's been my main diagnostic tool, though it's fairly easy to set a carb where the HCs are to high most of the time. Mine has FI which controls the mixture. Worth checking at some point though.
BTW, does your Howell system control timing for you? FiTech also has that now. Mine does not, though.
After a couple of years, my rig is usable and I know my engine and transmission are solid. This is my first big block engine and I'm finally at the point where I can start tweaking various tuneup parameters to increase power and mileage (Recurve of the distributor is a strong possibility, though I'll need to set up a timing monitor setup to really see what's going on. My primary job was usually tuneup and electrical, plus the aforementioned emission testing and I think I'll be fine after driving/adjusting it for a bit. Trips will be short if this global energy convulsion continues.
Prior to purchasing my GMC I hauled a 9000 plus pound trailer with a 1 ton Ford van. I had built a 10 to 1 high compression 351 which pulled the 13000 pound load wonderfully. I also encountered pinging under load using 93 octane fuel. Using high test is mandatory with that much compression. I installed a water injection system which completely eliminated the problem. An additional benefit is never building any carbon on those high performance pistons.
Reactions: mech0001
Is your "Water Injection System" an HHO or Brown's Gas system? If so, you are increasing the oxygen percentage in the intake compression air.
Most people are virulently bashing this system. The deceased Chuck Botts had installed such a system. He had a carbonated COOP 455 engine.
According to Chuck, he got 13.5mpg but had a great deal of trouble keeping it to work properly. He had to drive at 58mph to get these results.
Please advise if you plan to install such a system on your coach's 455 and is it carb or fuel injected?
