Hi Ken-
There are a few things come to mind-
#1 is is there a chance you are using the wrong dipstick, or the tube it
attaches to? Perhaps the engine is being slightly overfilled and foaming up
the top quart or so from windage. This will make for very high oil
consumption until the level drops a bit. Many factory GM engines I've had
burned the top 1/2 quart off in 250 miles, then essentially *nothing* for
the next 3000. Even correct parts can occasionally be slightly out of
calibration.
The only three ways out of the sump the oil can leave without leaving a
visible external leak is past the piston oil rings, down the valve guides or
up the PCV tubes. a Quart in 100 miles is very visible as exhaust smoke
usually if its being burnt, you'd have a good blue haze following you.
Judging from the compression, it doesnt seem too likely its rings. Does the
blowby 'puff' or pulsate?
If its going down the guides, it will be quite sensitive to throttle
opening, probably use much less at 75 mph than 50 mph- with rings, the
reverse would be true as a rule.
In light of the fact the engines just been overhauled, I suspect oil level
might be the issue. You may want to drain and refill it by the book to
ensure that its not overfilled. Theres other possibilities of course, but
lets not get too worried yet;-)
Good luck!
Brent Covey
Vancouver BC
> Help!
> I rebuilt the engine in my 76 Birchaven about 3000 miles ago
> and quiet and has plenty of power but is using a quart of oil every one to
> two hundred miles! There are no oil leaks visible -- except in the air
> cleaner.
calibration.
Good luck!
Brent Covey
Vancouver BC
> Help!
> cleaner.
