455 crankshaft wanted.
7,022
4
Does anyone in Oregon, Washington, North California have a STANDARD SIZE
crank for a 455. O.K. if it needs polished, or turned .010" or less. Call
or email me if you can help.
> crank for a 455. O.K. if it needs polished, or turned .010" or less. Call or email me if you can help.
> Salem, Or
Jim,
Did you know that there are Three Crankshafts for 455?
There is Cast Iron, used in most passcar applications.
Then there were Nodular Iron used in many performance cars and in some marine and apparently some motorhomes.
There are also some Forged Steel cranks that were supposed to go to the industrial and some went to motorhomes.
When I got my coach's engine open, it had a nodular crank, and of the two salvage engines, one was noodle (an engine builder joke) and the other was a
cast.
The Iron and Noodle can only be differentiated by an N on the front throw.
Matt - whose recent rebuild survived the incident.
Matt, there are at least 2 more. Crusader Marine specified a forged crank
for a 455 for their engines. I used to work on gill net fishing boats
equipped with them. Alas, all my examples have been ruined by exposure to
the dreaded SALT WATER associated with offshore fishing boats.
The final example was used in the actual HURST OLDSMOBILES that were
used in drag racing. They were precursors of "funny cars" and used some
really trick stuff. Among the speed parts were cast iron headers that
blocked off the center heat passage and divided the siamese center exhaust
port, solid lifter camshafts, all gear camshaft drives (no chains), deeper
oil pans with windage trays, main bearing girdles, and finally, billet
steel crankshafts, for manual transmissions. These pieces are long gone,
now. All in the hands of collectors or in junk piles.
The best we can hope for today is the modular iron cranks used in
motorhomes, agricultural applications, and some Mercruiser engines used in
jet boats.
On Sat, Apr 13, 2019, 4:39 PM Matt Colie via Gmclist <
> > Jim Hupy
> > Salem, Or
> Jim,
> cast.
My spell check changed nodular to modular. Grrrr.
> jet boats.
>> > Jim Hupy
>> > Salem, Or
>> Jim,
>> cast.
I had that problem too.
what email client ar you guys using?
Mine suggests corrections, and lets me make the decision.
On Sun, 14 Apr 2019 07:47:47 -0600 Matt Colie via Gmclist
> > Jim Hupy
> Matt
Ron & Linda Clark
North Plains, ORYGUN
1978 Eleganza II
Not the server, it is my cell phone.
On Sun, Apr 14, 2019, 8:55 AM rallymaster--- via Gmclist <
> > > Jim Hupy
> > Matt
> Ron & Linda Clark
> 1978 Eleganza II
It's supposed to be a "smart phone", send it to school. ;-)
Ron
On Sun, 14 Apr 2019 09:00:51 -0700 James Hupy via Gmclist
Ron & Linda Clark
1978 Eleganza II
If you select "spell check" and delete "autocorrect" those are far more satisfactory options. Spell check will challenge your spelling AND if you are sure you are correct with a new word, you can add it to your phone's dictionary!
D C "Mac" Macdonald​
Amateur Radio K2GKK​
Since 30 November '53​
USAF and FAA, Retired​
Member GMCMI & Classics​
Oklahoma City, OK​
"The Money Pit"​
TZE166V101966
From: Gmclist on behalf of rallymaster--- via Gmclist
Sent: Sunday, April 14, 2019 11:07
Cc: rallymaster
Subject: Re: [GMCnet] 455 crankshaft wanted.
Ron
Ron & Linda Clark
1978 Eleganza II
https://apc01.safelinks.protection.outlook.com/?url=http%3A%2F%2Flist.gmcnet.org%2Fmailman%2Flistinfo%2Fgmclist_list.gmcnet.org&data=02%7C01%7C%7Ccaf4b64197334e62fbab08d6c0f3b7a8%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636908550320323777&sdata=I6LzWlWQY8HZ76aRNeZIJm292S%2Fs2JaMYmUyOLPFheY%3D&reserved=0
