My spell check changed nodular to modular. Grrrr.
> Matt, there are at least 2 more. Crusader Marine specified a forged crank
> for a 455 for their engines. I used to work on gill net fishing boats
> equipped with them. Alas, all my examples have been ruined by exposure to
> the dreaded SALT WATER associated with offshore fishing boats.
> The final example was used in the actual HURST OLDSMOBILES that were
> used in drag racing. They were precursors of "funny cars" and used some
> really trick stuff. Among the speed parts were cast iron headers that
> blocked off the center heat passage and divided the siamese center exhaust
> port, solid lifter camshafts, all gear camshaft drives (no chains), deeper
> oil pans with windage trays, main bearing girdles, and finally, billet
> steel crankshafts, for manual transmissions. These pieces are long gone,
> now. All in the hands of collectors or in junk piles.
> The best we can hope for today is the modular iron cranks used in
> motorhomes, agricultural applications, and some Mercruiser engines used in
> jet boats.
> Jim Hupy
> On Sat, Apr 13, 2019, 4:39 PM Matt Colie via Gmclist <
>> > Does anyone in Oregon, Washington, North California have a STANDARD SIZE
>> > crank for a 455. O.K. if it needs polished, or turned .010" or less.
>> Call or email me if you can help.
>> > Jim Hupy
>> > Salem, Or
>> Jim,
>> Did you know that there are Three Crankshafts for 455?
>> There is Cast Iron, used in most passcar applications.
>> Then there were Nodular Iron used in many performance cars and in some
>> marine and apparently some motorhomes.
>> There are also some Forged Steel cranks that were supposed to go to the
>> industrial and some went to motorhomes.
>> When I got my coach's engine open, it had a nodular crank, and of the two
>> salvage engines, one was noodle (an engine builder joke) and the other was a
>> cast.
>> The Iron and Noodle can only be differentiated by an N on the front throw.
>> Matt - whose recent rebuild survived the incident.
>> Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
>> Electronically Controlled Quiet Engine Cooling Fan
>> OE Rear Drum Brakes with Applied Control Arms
>> SE Michigan - Twixt A2 and Detroit
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
