410 final drive
Racer20m
6
1
Can anyone help direct me to be able to find a USED set of 410 ratio gear set or final drive untit, or maybe a salvage yard that may be able to help?
Why do you want a used set of final drive gears?
If I went to the trouble of changing out the assembly, I would use
the best thing I could get my hands on.
Don't apply false economy to mechanical repairs, your coach and
Murphy will conspire to leave you alongside the road, at night, in the
rain, with semi trucks flying by so close that the wind rocks your coach.
78 GMC ROYALE 403
Who is this person?
Mike in NS
> Salem, Or
> 78 GMC ROYALE 403
> help?
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
You won’t find any in a junkyard. Jim Kanomata of Applied GMC developed it and modifies a standard final drive with different gears. Contact him at 800-752-7502.
Frederick, CO
> Its for a off road project im working on using the th425 trans.
O.K. that explains it a bit. There was never a 4:10 ratio produced by the
factory for production. Common ratios were 3:07, 2:73, and a very scarce 8
bolt unit. Aftermarket units are 3:70, 3:55, and 4:10. Applied GMC in
California should be able to help you. Manny T. has different chain drive
ratios for inside the transmission. Don't know all the ratios there.
Yes, i have been in contact with applied, but unfornuately my budget on this project wont allow me to spend $1800 on a unit or $900 on a gear set, so
was hoping maybe someone had a used one or maybe someone that has already changed units may have hit the salvage yard. I was hoping maybe someone here
may be able to help me find something any help would be greatly appreciated.
You might get lucky and find a used final drive with the 3:70 or 4:10 ratio, but it won’t be cheap. Used FDs with the 3:55, 3:70,or 4:10 ratio in useable condition can sell for over $1000, while new are a fair bit more.
To find a used high ratio FD, you’ll have to keep a very close watch on all the various GMC Motorhome for-sale listings that exist across the web. Parts like these will sell quickly if the the price is fair.
There are many GMC related lists of stuff for sale. Start searching all the clubs, groups, forums, Facebook groups, etc. Even some of the suppliers have lists of used parts that they offer for sale. You WON’T find it all listed in one place. Often the good stuff sells by word-of-mouth before making it to a list, so many phone calls might be in order to find your parts.
Good luck with your search.
Les Burt
Montreal
'75 Eleganza 26'
> Emery Stora
> 77 Kingsley
> Frederick, CO
There are over 3,000 3.70/3.55 out there.
4.10 are but 200 ea.
If you need help to locate a used one, posting it here is a good start.
> parts.
> Les Burt
> Montreal
> '75 Eleganza 26'
> > On Aug 29, 2018, at 11:08 AM, Emery Stora via Gmclist <
> 800-752-7502.
> > Emery Stora
> > 77 Kingsley
> > Frederick, CO
> >> GMCnet mailing list
One option would be to combine the transmission chain ratio change with
say, a 3:70, that might be a more achievable salvage find to get shorter
gearing.
> so
> appreciated.
I have read about the chain/gear swap and yes that may work aswell, for my project i plan on bolting up a 4.3 liter v-6 to the th425 and will only use
1st gear and reverse, so in order the the v-6 to pull a 3,000 lb car i need to change the ratio to make it perform, where does one find more info and
costs of the chain/gear swap?
Do not try to get the gear set. Then have you, or someone else install them in the case. PROMISE. Been there. Done that. I've installed a lot of gear sets in about everything. I will NEVER do that EVER again in one of these cases. Don't even think about it. EVER. Bob Dunahugh
Check Mannystrannys.com.
> and
For starters, the gears won't go in the case. You have to expand it a bit. Etc. Listen to Dunahugh, he knows whereof he speaks. Either get a power
dive chain set from Manny if he still has any and pair it with a 3.7 or put more motor in and build it for a lower engine speed. Meantimes, tell us
who you are and where - there may well be someone relative close to help.
Like any rear end, you need a spreader. Does not make any differencce as to
ratio.
All our gears work like the stock.
Setting up the ring and pinion is not that hard, just triccky if you want a
quiet unit.
On Wed, Aug 29, 2018 at 4:52 PM Johnny Bridges via Gmclist <
> power
> --johnny
> Braselton, Ga.
Here's a suggestion for you. Several years ago I found some info on the net
where a guy turned the engine and tranny around, converted the tranny to an
open driveshaft, using RWD car parts. Then he used a FWD axle assembly.
This got everything turning in the right direction.
Cheaper deal and a good selection of gear ratios. To really go big time,
since it's a FWD axle, cut the axle tubes and rotate them 90 degrees,
weld them back together and you now have adjustable camber using the tie
rods as adjusters.
That's my contribution to keeping you out in the garage for a while.
Gary Kosier
77PB w/500Cad
Newark, Ohio
them From: .
Sent: Wednesday, August 29, 2018 12:52 PM
To:
Subject: Re: [GMCnet] 410 final drive
> use
> 1st and reverse, so in order the the v-6 to pull a 3,000 lb car i need to
There you go thinking about it. DON'T. GRIN. The case has to be bent by a special spreader. There's just no room in there. I did it in 2004. I'm sorry. I let those bad memories die years ago. And what's left of those memories have made me enjoy messing with my 4 original COPO Yenko's even more. Bob Dunahugh
Sent: Wednesday, August 29, 2018 12:22 PM
Subject: RE: 410 final drive
