Arch,
Thanks for the input, I'll pass it on to my machinest. I am not going to
use the Caspro cam, Crane cams are built here in Daytona and I think they
have one that will do the job. For the sake of evaluation and that I want
the motors to be mainly stock except for a few changes, I think we will
build the motors equal and see what we have. The customer with the
completely stock set up has been pleased with his coach performance for
many years so anything I do to it will be a plus. The coach with the gear
set up wants to pull a tandem wheel trailer better than he did before with
was already acceptable. Both of these guys will be happy with whatever
comes out, anything will be better than what they had.
Until Nate is happier with the performance of his Caspro motor, I'm going
to stick with my tried & true builders & less than radical mods internally.
I want to build a reliable workhorse- guaranteed. , not a finicky lady
that will leap on a good day. Nates motor has some quirks that I want to
see cleared up before I go further. Chuck wants the dist. back to do some
checking and I want to find the reason for the quirks.
In evaluating the results of mods, you have to progress one step at a time.
It will be interesting to see what the few mods we will be doing effects
the 403 set up. By the way, I will be able to compare the new motors to a
good stock 403 which we have in Chucks coach that will get the Cady set up.
It will be interesting!!
Jim Bounds
>In a message dated 12/18/1999 4:12:34 PM Central Standard Time,
>> I have 3 403 coaches in the shop for engine work side by side. One engine
>> is going to be rebuilt with stock gears behind it but we're going to beef
>> up the motor with a cam, forged pistons, and a few other things. The
>> second one gets the same engine set up but with the full Caspro set up and
>> the 4 air bag system. The third coach gets a Cady engine swap.
>JIM
>OMG now you are going to push me all the way out to the edge.
>Glad to see one will be stock gears. If you are going with the Caspro
>cam it should be fine. Somewhat stronger than it was. What compression
>ratio and did you block off the crossovers on either? Now what do you
>mean by full Caspro set up behind the second one? Are we at 3.55 gears?
>If you are at 3.55 and a Caspro cam then I think this one will have torque
>all over the place at low end but run out of steam on top end. If it is a
>Mondello cam you should be good to go to 3200 at least depending
>on how they degree in the cam. Jim talk to the people you trust. I am
>only spouting theory. On the coach that you are putting the 3.55 gears
>behind the engine you might want to retard the cam 2-4 degrees. If it is
>a Caspro cam. Talk to Chuck he should have something to say on this.
>I really dont think the two engines should be set up the same----more
>theory. Now the one I want to hear about is the Caddy. What gears are
>you putting behind it? There is a relationship between torque and weight
>that I have not seen mentioned. You can increase the RPM of an engine
>to increase horsepower only so far. If you are starting down the backside
>of the curve with the extra RPM you have accomplished nothing. I dont
>even know where the Caddy begins to strut it's stuff. I do think that if it
>is designed for a 6000 lb car and you put it into a 12000 lb motorhome
>you will want to up its RPM----unless it puts you on the down side of the
>curve. Jim its all theory---talk to people you trust.
>Take Care
>Arch 76 GB IL
Jim Bounds/Co-op Motor Works Orlando
www.gmccoop.com
