317 adapter plate for front radiator driver side compressor set up.
ron & gina
397
Hi Scott,
I haven't taking any measurements, Just a rough check and on mine looks like
it'll fit both ways, lengthwise comes close to floorboard but should clear
with no problem with more room sideways, I'm going to install lengthwise.
Was going to make/have a plate made but got laze and ordered one from
Cinnabar $20, P/N 3171. If you want some #s let me know where and I'll get
it.
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ. (lived in NoCA. for 35yrs, here 6 months and felt my first
earthquake this morning,Now thats power!!!!!!!!) :-(>
To:
Sent: Saturday, October 16, 1999 7:16 AM
Subject: GMC: 317 adapter plate for front radiator driver side compressor
set up.
> Gmcers!
> I have a 75 PB---
> I need your help--if your compressor is where mine is, next to driver side
> radiator. Since my frame and coach are not together. I don't know how
much
> room I have to play with. I am trying to make a retrofit adapter plate to
> mount the new compressor. I am assuming you have the Dana compressor
mounted
> like mine. I don't see any problem side to side. My problem is trying to
> find out what obstructions are in front and in back of the compressor. If
> you look at your compressor, can you possibly tell me what clearances in
> inches in front and back of the Dana --before I would hit an obstruction?
> The mounting plate of the original Dana (also the radiator support
bracket)
> has a 7/8" 90 degree flange at the back. My tentative plans now are to
cut 3
> small bushings 1", out of 1/2 black pipe, which is approx. 1/8 inch taller
> than flange. Make a plate 4 1/2 x 9 1/2, drilling holes through plate to
> match Dana mounting holes. Drill holes to mount 317.
> Therefore the overall footprint would be 4 1/2 X 9 1/2 plus 1 1/8 inches
> higher. Anyone have any input?
> Scott NEHODA'S
> BACK YARD
