Tyler,
I copied this from Harbor Freight:
Specifications
Name 3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid PumpR
SKU 61282
Brand Pittsburgh Automotive
Material Steel
Quantity 1
Handle Length (in.) 45-1/4 in.
Maximum Lift Height (in.) 19-3/4 in.
Minimum height (in.) 2-7/8 in.
Product Height 6-1/4 in.
Product Length 27-1/2 in.
Product Weight 71.7 lbs.
Product Width 13-1/8 in.
Shipping Weight 75.80 lb.
Size(s) 3 ton
Specifications
Name 3 ton Steel Heavy Duty Floor Jack with Rapid PumpR
SKU 68048
Material Steel
Quantity 1
Maximum Lift Height (in.) 18-1/4 in.
Minimum height (in.) 5 in.
Product Height 6-1/8 in.
Product Weight 68.9 lbs.
Product Width 13-1/2 in.
Shipping Weight 73.30 lb.
Size(s) 3 ton
Specifications
Name 3 Ton Aluminum Racing Floor Jack with RapidPumpR
SKU 62248
Certification ANSI
Material Aluminum, steel
Maximum Lift Height (in.) 19-1/8 in.
Minimum height (in.) 3-5/8 in.
Product Height 6 in.
Product Length 26-3/4 in.
Product Weight 55 lb.
Product Width 14-1/2 in.
Shipping Weight 68.60 lb.
Size(s) 3 Ton
The Pedantic Mechanic
USAussie - Downunder
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Tyler
Sent: Wednesday, November 09, 2016 1:02 AM
Subject: Re: [GMCnet] 3 Ton Jack
The coupon is for the low profile, which is a little more money than the standard jack. I would be curious if lift height is same as
the regular one.
1975 Glenbrook
Raleigh, NC
