3 ton floor jack
joe williams
31
can anyone tell me if a 3 ton floor jack is heavy/safe enough to lift the front end of the Royale?
3 ton jack stands?
what do most of you use?
thanks Joe
Joe Williams
1978 Royale rear twin
I have a Craftsman (made in USA) 3 TON quick lift floor jack. It grunts
pretty good lifting the front end of a GMC. I use 2ea 6 ton jack stands to
support the front end, once it is airborne. They are placed under the frame
behind the front tires where the front clip is bolted to the frame rails. I
use them only on level concrete floors.
3 ton jack stands?
thanks Joe
Joe Williams
Joe,
The front of my Glacier is the full 4300 that the paper says (My house bank is in the front) and a 3-ton jack does just fine.
Just be sure it is under the middle (where the holes are) of the front cross-member.
Hazard Fright jackstands are rated by the pair. So they are not as stout as you might think, but still, a pair of 3 ton should do. Mine seem to be.
I use a 15 year old Craftsman 3-1/2 ton floor jack and a pair of 4-ton jack stands for the front, 6-ton jack stands for the rear.
Even with the 3.5 ton jack, it is a job to lift the front from the center, or either side from the bogie frame.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Joe,
I have a Harbor Freight 3 ton floor jack that I bought at least 4 years ago and it works just fine.
Also from HF I have:
4 ea 3 ton jack stands
4 ea 6 ton jack stands
4 ea 12 ton jack stands
Why the 6 & 12 ton you ask - they go higher.
If you are concerned about the jack stand collapsing you can do this:
http://www.gmcmhphotos.com/photos/g6101-jack-stand-security-pin-mod.html
Torin jack stands from Northern Tools come with this feature.
Regards,
Rob M.
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Joe williams
Sent: Wednesday, July 12, 2017 12:45 AM
Subject: [GMCnet] 3 ton floor jack
3 ton jack stands?
thanks Joe
> 3 ton jack stands?
> thanks Joe
These home made jackstands are good for at least 12 tons. Inexpensive, stable, secure.
http://www.gmcmhphotos.com/photos/g5461-12-ton-jack-stands.html
A number of GMC'ers have made these. I've been using these for over 30 years.
Steve Southworth
Palmyra WI
Looks great Steve.
Very similar to what I made way back in 1970 to use with my Travco motorhome.
I used old full size 2x4 lumber from a remodel of an 1880 house, probably oak.
I didn't glue the joints but they work well 47 years later. They have 2 nails at each end.
Your write up will make it easy for GMCers to make them.
Emery Stora
77 Kingsley
Frederick, CO
>> 3 ton jack stands?
>> thanks Joe
> Steve Southworth
> Looks great Steve.
> Emery Stora
> 77 Kingsley
> Frederick, CO
Makes no difference between a nail and glue or two nails at each end. The glue/nails only serves to keep them alighned and together. Once the load
is on them they aren't going anywhere. The album is a JWID thing and shows a basic design. There can be many modifications and personalization
possible.
Steve Southworth
Palmyra WI
