Gee, thanks for that explanation
Really more than I needed to know
Reminds me of the old saying” Ask an engineer what time it is and he will teach you how to build a watch“
Sent from my iPhone
Nelson Wright
Orlando Fl.
> Hi Nelson,
> Not counting any other losses, just the energy to heat the water, the
> time would be calculated as follows.
> 6 gallons at 8.34 lb/gal = 50 lb of water.
> 1 BTU = the heat required to raise 1 lb of water 1 degree Fahrenheit.
> 1 Kilowatt hour of power = 3412 BTU X 1.125 = 3839 BTU available per hour with
> an 1125 watt heating element.
> 3839 BTU divided by 60 minutes = 64 BTU available per minute divided by 50 lb of water
> equals a temperature rise of 1.28 degrees Fahrenheit per minute.
> Therefore heating the tank of water from 70 deg. to 130 deg. or a 60 degree rise would take
> about 47 minutes (60 divided by 1.28). Of course with such a small tank, to get a longer shower
> time starting with a higher storage temperature is necessary, so you can mix more cold water to
> extend the shower time.
> Marsh Wilkes
> Perry Fl
> -----Original Message----- From: Nelson Wright via Gmclist
> Sent: Thursday, April 30, 2020 10:14 PM
> To: gmclist
> Cc: Nelson Wright
> Subject: Re: [GMCnet] 240v water heater element
> Thanks Marsh,
> So it will heat the water albeit somewhat slower. Is 1125 watts reasonable for heating 6 gallons?
> Sent from my iPad
>> Hi Nelson,
>> A standard 4500 watt 240 volt element will give you 1125 watts on 120 volts.
>> Marsh (rarely post) Wilkes
>> Perry Fl
>> Sent: Thursday, April 30, 2020 9:21 PM
>> To: gmclist
>> Cc: Nelson Wright
>> Subject: [GMCnet] 240v water heater element
>> If I recall correctly it was recommended to replace the original 120v element with a 240v element. This water heater has the 4 bolt mount element which is dead, but otherwise the tank is good. I found one with the correct bolt pattern but it’s 240v. Is this going to work with 120v?
>> Nelson Wright
>> 78 Royale rear bath
>> 73 GMC Restoration
>> Belle Isle Fl
>> Sent from my iPad
