The base is connected to wood and frame. I'm not knowledgeable enough on
the topic to quote how much force the seat base is designed for, but i can
say that the mounting of the seat belts appears much beefier than the
seats. Others will have more experience on the topic, and it has been done.
I wonder if their solutions still allow for rotation?
I wouldnt trust ~250# at a 60 mph to that bolt. =)
On Thu, Sep 12, 2019 at 10:29 AM Kevin via Gmclist
wrote:
> Will, Thats what I was thinking, but there must be a way to achieve the
> best of both worlds. Has anyone been able to incorporate the mounting points
> of the original seatbelts into a replacement seat, whether by cabling or
> other such method? Is the pedestal the seat sits on securely mounted to the
> frame through the wood flooring?
> Thanx
> > Kevin,
> > The mounting system of the seat is your weak link here. The shoulder belt
> > is giving you a false sense of security when the seat itself is held on
> by
> > a single bolt. While the belt will keep you attached to the chair, what
> is
> > keeping the chair attached to the vehicle?
> > The OEM system holds you against the chair, secured at the floor.
> > To that, I'd still recommend the Odyssey seats. I have a later model set
> in
> > my rig, but i utilize the lap belt and their mounting points.
> > -Will
> > On Thu, Sep 12, 2019 at 9:58 AM Matt Colie via Gmclist <
> > > Kevin,
> > > Welcome to the group, family, cult, asylum....
> > > I am very glad that you found your way here to get the good
> information.
> > > Sorry I am so late getting to you, but I have been very busy.
> > > However, you need to do both yourself and us a favor. This is just
> so we
> > > can do a better job of assisting you along the way. You are working
> the
> > > list as the forum, so this is easy. Go to Settings> and find .
> There you will find a Signature box.
> > > Fill in a
> > > name you like to be known as (real is best), a short about the coach
> (your
> > > first post mentioned 77 Royale, add if it is a 403 or 455) and
> geographic
> > > reference (central MA will not be seen by those that get this as
> email -
> > > about half). This way, two things, when you meet other owners they
> will
> > > know
> > > who you are and when you ask questions, the replies can be Coachmen
> > > specific. This is good all around.
> > > If you have not, you will soon discover that the coach is much more
> than a
> > > big new toy because it connects you to this community. This is a
> community
> > > of helping and supportive people that is both amazing and rare.
> Because
> > > this reminds me so of that of the watermen of my world, I like to
> welcome
> > > new
> > > owners here much as you might be there. So,
> > > May the Good Lord bless this coach and all those that set forth within
> > > here.
> > > Welcome Kevin
> > > Matt
> > > Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> > > Electronically Controlled Quiet Engine Cooling Fan
> > > OE Rear Drum Brakes with Applied Control Arms
> > > SE Michigan - Twixt A2 and Detroit
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
