2 Roof Airsu
tim dawson
778
Go for it. I have dual 13,500 BTU units, and can run both, the water heater,
and pretty much anything else that I want to run with no difficulty IF a 50A
shore power receptacle is available. If all you get is a 30, forget it - single
A/C only or it will trip. Keep in mind that the 40A is a 240 Volt, two leg
feed, and the 30A is single, so you really get 80A of available power on the
50A outlet vs. 30A on the 30.
- - Tim
> Our 73 Pumpkin-Rose has on cable which looks stock 40amp, Asked P.O. and she
> said that was never touched. Was just wondering what I had. Thinking of
> adding rear air, Or upgrading 13500 to 15000btus. Unsure why it just doesn't
> get hot enough here. 8-)>
> Ron&Gina
> 73 Pumpkin-Rose
> Ft. Mohave, AZ. 70deg. Man is it cold
> ----- Original Message -----
> From:
> To:
> Sent: Saturday, January 29, 2000 1:29 PM
> Subject: Re: GMC: 2 Roof Airs
> > > Not to belabor this issue but early 75's came with 30 amp power cords.
> My
> > > 77 has a 50 amp.....
> > Dave,
> > Any chance you have a Transmode that was wired by an upfitter? My
> early
> > '75 (TZE.....397) was 50 amp from GM, and the GM manual wiring diagrams
> (back
> > to '73) are all for 50 amp. I think some of the other coachbuilders used
> 30
> > amp out of tradition.
> > I agree the stock 50 amp cord is a bit hefty to wind up when cold. I
> > think it was Emery who suggested winding it in the opposite direction,
> which
> > helps. I wouldn't give up my 50 amp umbilical for anything though. ;-)
> > Rick Staples
> > '75 Eleganza
> > Louisville, CO
Tim Dawson (tadawson) Owner/Engineer
TPC Services Bellnet: (972)-221-7385
Lewisville, Texas 75067 FAXnet: (972)-221-0393
"The world is complex. Sendmail.cf reflects this...."
Thanks Tim,
Now all I have to do is save up the $, Then figure out what on the list is
more important/needed. Thanks again
Ron
To:
Sent: Sunday, January 30, 2000 11:15 AM
Subject: Re: GMC: 2 Roof Airsu
heater,
50A
single
leg
the
> - Tim
she
doesn't
> > Ron&Gina
> > 73 Pumpkin-Rose
> > From:
> > To:
> > > In a message dated 1/29/00 7:27:23 AM MDT, davegreenberg1
writes:
cords.
> > My
> > > Dave,
> > early
diagrams
> > (back
used
> > 30
I
> > which
> > > Rick Staples
> > > '75 Eleganza
> > > Louisville, CO
(972)-221-7385
(972)-221-0393
