We were with some GMC people last weekend. And it was mentioned that one pe=
rson wouldn't leave till the engine was to full operating temps. It's true =
that there is less wear at full engine temp. But that temp is reached much =
faster while driving. As there is more fuel burned while on the move. Thus=
the engine has more BTU's used up in the process. The cylinder walls, an=
pistons have had 2000 degrees put to them. As to the oil getting moved aro=
und. In one minute. The oil filter, and all oil passages were full to start=
with. The oil pump has delivered about another 6 qts to get every moving p=
art lubed. The engine has had the crank rotate around 700 times in that min=
ute.. I'm sure there are lots of thoughts on this one. I use the one minut=
e idea. One of the things that help these engines last so long. ( As long =
as there maintained properly.) Is you don't use them for short trips. Thus =
less cold starts per mile. As a interesting side note. The 403 piston trave=
ls less feet per mile then a 455. So does a 403 piston/rings last longer? =
Bob Dunahugh 78 Royale.
