2,900 Mile Maiden Voyage?
I guess that I do not understand. I would probably have to see it to understand.
Thanks
Ken B .
Thanks
Ken B .
I'll make a better attempt. Run the chain through, let's say, a 10' pipe. Attach the chain to both vehicles and then bolt the chain together at each vehicle with the pipe as close as possible. If or when the toad moves forward, it stops after moving the pipe tight against both vehicles' chain. BTW, it doesn't need to be a chain. PVC might even work instead of pipe. With any luck at all, the toad shouldn't need to do anything but steer.
Well, I have searched the internet for almost an hour and have not found anything about the pipe and chain. My brother and I have used this method for years. The last time, I towed his F250 pickup for 80 miles at night on interstate and two-lane hi ways at 50+mph without any problems.
I've done this as well, it's more fun to be in the lead vehicle, very stressful to the one being towed lol
It definitely requires FAITH!
So you are connecting the single chain on both ends probably looped around a bumper brace ahd held togetheer with a bolt. No one is in the rear vehicle steering or braking. Am I correct? Sorry yo be so dense.
There would be a driver in both vehicles. The towed vehicle's driver needs to try to keep the pipe straight into the pull vehicle. If the pipe is at an angle and the pull vehicle hits the brake, it tends to push the towed vehicle off to the side thereby losing all the pull vehicle's braking ability rather quickly! It definitely has a high 'pucker' factor
It's actually easier than it comes across in conversation. All the toad needs to do is stay in line behind the puller, and it really isn't that difficult. Yes, if the toad was to be quite a bit offline and not correct and at the same time the puller applied brakes, depending on speed and severity of braking, you could develop a problem.
The technique is very handy for a short distance, slow pull when the toad driver is very reluctant in regard to braking (hitting the puller).
Something like this :)
We ran the generator and used a lab vacuum pump to provide vacuum to the booster for the drive home (200+ miles) at 45 mph.
I like that idea. I have a 120 volt vacuum pump on a vacuum cabinet that I could use.
Ken B.
I know someone has mentioned new belts. Having just done this, I can possibly shorten your search. O'Reilly sells Gates 7/16" belts as well as Amazon. A lot of stores and online stores do not. O'Reilly wants around $30 a belt. Here are the numbers and prices at Amazon:
Gates 7612 XL High Capacity V-Belt (A/C) $14.33​
Gates 7440 XL High Capacity V-Belt (PS) $12​
Gates 7570 XL High Capacity V-Belt (Alt) $14.53​
BTW: I have read different ways of attacking this job. I slipped the alternator belt over the fan first, then the power steering belt. Fit & adjust the PS belt first, then the alternator, lastly the A/C.
Hello there my 23ft Birchaven brother! I've been having trouble fitting an alternator belt on mine. I've tried the O'Reilly's 7560 and it way way too tight to fit with the alternator pushed PAST maximum adjustment. I took it back to the store and sized up at 7575 and that didn't look much bigger. Do you have any secrets or tips to make this work?
Do tell. Best wishes!
